03 Tahoe Code P0116- FIXED
Dantheman-2003
Placerville, Ca
So I just finished my electric fan conversion on the Tahoe. Installed the Blackbear performance tune. Everything seems to work fine, except when I went for a test drive the temp gage dropped to zero. E fans working fine, gage temp initially went up to about 200. During test drive dropped to zero. Plugged in my Auto Cal and showing code P0116. Thoughts? I’m going to email Blackbear as well. I do have some other codes now that I didn’t have before.
nonickatall
Germany
I guess you did something electrical on the temperature sensor, so probably you have a problem on the wiring.
Especially when the code is p0116 and your gauge drop to zero.
So tell us what you did and/or check the wiring...
Dantheman-2003
Dantheman-2003
Placerville, Ca
I’ll take another look today. Pretty basic setup. OEM harness, blue/black & grey/ yellow to fans. Red to power, black to ground. 2 PCM wires, green to pin 42 and blue to pin 33. Uploaded tune file and into the end zone for a touchdown. Except now the temp gauge issue and P0116 code. Like I said I’ll take another look at the wiring and also reach out to Blackbear
nonickatall
Germany
But did you change something on the temperature sensor harness? It located close to the steering pump.
Because the p0116 says "Engine to cold" wich is, because you have 0 temperature, as seen additionally on the gauge, which means, that something with your temperature sensor ist not correct.
Maybe the connector is not appropriate in place?
Dantheman-2003
Dantheman-2003
Placerville, Ca
Yeah for sure that code points to the temp sensor. But I never messed with it. Never touched it. Ima take a look today and will circle back.
Dantheman-2003
Dantheman-2003
Placerville, Ca
UPDATE: So I disconnected the battery, went back through the wiring, and now all good. Everything working as it should. E-fans engage at around 205 degrees. Super happy with this project thus far. Thanks to all for the support.
RAMurphy
Bob
S. Maryland
Glad the problem is fixed. Add to your thread title that this was "fixed " or "resolved".
Simpson21
