03 Denali new on the scene
Flexxicon
I'm a newbie in the forum but the wealth of knowledge and the actual willingness to share is remarkable.
I'm looking to basically go through the engine and make sure how things are operating and replace etc.
I would like input of middle of the road mods for performance etc and how to maintain my tranny or mod it also.
Much respect to the forum and looking forward to the brotherhood.
95escahoe
Post up some pics of the truck, first thing I would do is drain and refill the rear end, front diff, and transfer case, drop the trans pan replace the filter and top it off, unless you have service records, the front diff on the AWD Denalis and Escalade can cause issues if not properly maintained, I’d pay a shop to do a safety inspection and see if there’s anything they would suggest doing so you have an idea of where your at. Mod wise you could do a cat-back exhaust or just throw a new muffler on, e-fans are a worth while mod, get an Airaid intake tube and filter and a BB tune would be good too, that’s really all the basic performance mods you could do headers, a cam, supercharger etc. all depends what you want to get out of the truck.
Welcome. We need some pics of that beauty. X2 on the fluid change and safety inspection. Gotta know where you're at mechanically first. One good mod to do us a catch can. Catches any oil blowby before it gets into your intake.
95escahoe
X2 on the catch can
F
Flexxicon
Thank you I appreciate all the words of wisdom.
I'm away right now working so I'll be getting back and attacking the direction the goats are sending me in.
Will be putting up the pics as soon as I get back.
latvius
Ariton Alabama
Welcome! (I'll have to look into getting a catch can, learn something new every day!)
I would do the tranny flush, their is a write up on how to change out all the fluid in the tranny. Black Bear tune is a must, makes a world of difference.
For air intake I bought an ebay non brand for $50, it's a lii cheezy but is working fine.
If you change your serpentine belt and tensioners might as well change the water pump while you are in there.
F
Flexxicon
Respect lativus
I'm learning so much just by the little Tony and escahoe have dropped on me. I didn't even know what a catch can was nor what it does lol.
Appreciate the love.
KookyKoala
somewhere, IA
welcome, dont know if it was mentioned but if your transmission is in good shape I'd do a Corvette servo helps firm up 1-2 shift. But have to agree with others, airaid intake tube, catch can (still need to do this to mine), if your in near water pump look for drips coming from behind the pump if theres water change pump before gasket fails completely, and super easy change. I'd also flush and refill coolant, while doing fluid
F
Flexxicon
Corvette servo? Is that an electronic piece? What's it's advantage?
F
Flexxicon
OK so I'm still figuring how to use this tapatalk so I'm having issues posting pics from my phone.
jasonc
Welcome im also a newby and have a wealth of knowledge to share also
F
Flexxicon
Respect Jason
Looking forward to absorbing as much as possible
F
Flexxicon
Going with some of the points I've received from Tonyrodz and escahoe and I've setup with a shop to go and do the checks and fluids. I'd like to pay extra attention to the tranny and the servo that was mentioned looks like some I want to explore.
Ordering air raid as I type...
The vette servo firms up the shifts in the transmission. Non electric, kind of like a piston--sort of. You can access it without dropping or going inside your trans, it's external. Hopefully someone can explain it a little better. I have it in my Hoe and it shifts amazing. Nice and firm. I also have other mods too.
F
Flexxicon
I'm definitely going with the servo.
I also saw some drips of oil on the ground under so I'm hoping nothing major
95escahoe
Could be a leaky oil cooler line, oil pan gasket, rear main seal, hard to say without knowing where it’s leaking from
F
Flexxicon
Respect hihoesilver
Great info. Definitely considering a setup like this
YPNHighCountry
