Randy Whistler
Living the dream! I'm just not sure who's dream
The ABS and ABg relay/modules(whatever they're called) were removed before I got the vehicle. From what I've read, I believe that the ABS modules are generally removed because of ABS hub problems, etc., but other than killing off the ABS doesn't affect the driveability. Also, again from reading, the ABg module is generally removed due to seat sensors being problematic. Again, as I understand it the airbags may not work but other than that, doesn't affect driveability.
I also think I've read that the cruise control will not work with the ABS module out. Must be right, my cruise does not work, and the ABS module is missing. . .
So, first off, is this info basically correct?
Second, what would happen if I would replace these modules as-is? I really have no idea what issues there may be/have been when the modules were removed, and though while I was going through things that may be another couple of systems to take a look at. However, since the truck is doing just fine without both modules, I hesitate to fix something that isn't broke!
I'll go set in my corner now, for a little while . . . .
