VLOM removed from valley cover
nitro498
Deleted DOD. Plugged oil towers and removed VLOM from valley cover. Will this cause the engine to suck oil into the intake?
j91z28d1
I'm confused... you did what?
removed the vlom solenoids from the cover and reused the cover instead of a flat one? if so, did you plug off the oil passageways in the cover to solenoids? if not, it not. that isn't good.
I'm not sure how oil would get inside the intake from the mods thou?
need more info
N
nitro498
I drilled and tapped the 8 risers that supplied the VLOM. I watched a video of a guy that did the same thing. When he runs the engine oil is sucked out of the valley and deposits said oil into the intake.
j91z28d1
you have the oil flow backwards. it's flows from oil pressure sensor port down into the engine thru those 8 ports you blocked off to the afm lifters. you'll have a major internal oil leak if you don't plug that.
I honestly have no idea about sucking the oil into the intake. maybe some other guys will help with that.
B-train
I don't see how it's possible to get it to the intake. 2007-09 6.2L just had a flat valley cover the blocked off the ports with o-rings. When they went bad, oil pressure would drop when hot......it never ended up in the intake.
The only way to the intake would be through the PCV system. Even with higher oil pressure/volume, I don't see this as being realistic.
j91z28d1
so I'm half wondering if the oil passageways in the volm cover isn't plugged up up it sprays so much oil more of it ends up in the valve cover?
or it's just 2 different issues. my catch can catches some oil anyways?
j91z28d1
I wish I could find that video. It’s all good though.
if you can that would help.
my suggestion is to buy a flat non afm cover plate. they are cheap or you can buy a oil block off plug for cheap.
like this.
MWD_CTSV
Factory AFM/DOD is designed to provide oil pressure via the VLOM towards the DOD lifters when activated and release back-pressure from the DOD lifters when not activated.
If you are disabling AFM/DOD and keeping the stock lifter you need to leave the towers unblocked so that no oil pressure exists at the towers to activate the DOD lifter unlock.
If you are doing a full DOD delete and replacing all the lifters with a non DOD lifter, you need to block the tower holes because non-DOD lifters will very likely leak oil out of the tower passages and lower oil pressure.
MWD_CTSV
Also if you are deleting the VLOM solenoids, you need to block the oil pressure passage that feeds them, because they are under constant oil pressure and removing the solenoids will also cause oil pressure loss, unless you switch to a non DOD valley cover.
ibarra503
i can confirm! wish i wouldve done more research before doing exactly this! Massive internal oil leak leaking into combustion chamber. DO NOT USE FACTORY VLOM COVER WITH SOLENOIDS REMOVED!!
j91z28d1
how does oil leak get from the lifter valley into the combustion chamber?
while its definitely not good to have an oil leak pressure wise, but I feel like you might have a bigger issue if it's making it unit the intake runners?
mikez71
Perhaps an oil pressure leak into the valley can mist up? Getting pushed up around the pushrods, under the valve cover and into the PCV?
IDK, that's all I could come up with..
mikez71
If you haven't plugged the oil feed yet, I think that product is post #8 would be worth a shot.
It's $14 and you only need to access the oil pressure sender to install it I believe..
It's either that or a new valley cover, I think..?
j91z28d1
if they still have the afm lifters in there do not run a smooth lifter cover that blocks the afm oil holes.
mikez71
Shouldn't matter I would think with the solenoids removed and AFM de-activated?
Or is at another lubrication passage for the AFM lifters?
j91z28d1
yes, the oil towers go straight down to the afm activation ports. if you block those off, either way the bearing mod or the flat valley cover. the oil. pressure finds. away up in there from the normal hydraulic part of the lifter and releases the pins and the Afm lifter collapses and stays stuck.
if you have afm lifters in your engine those oil Towers have to stay open. once you swap to standard lifters do whatever you want with them.
mikez71
OHHH.. I see now..
So the towers always fill up with oil from the cam.
So the VLOM bleed off ports, bleed the air from the the circuit.
(And bleed off the pressure when AFM deactivates)
Thanks for the clarification!
Conedaddy
