builds4christ
- Joined
- May 14, 2024
- Posts
- 78
- Reaction score
- 52
Hey all,
Sorry if I'm beating a dead horse here. Just looking for some wisdom.
Got an 08 L92 Yukon. Picked her up pretty cheap! She's got 193k and seems to run well.
Had low oil pressure when I got her. I dug in, melling pump with the spring that came in it, new pickup tube and oring, removed the relief valve in the oil pan, new oil pressure sending unit, new dipstick tube oring, threw in some 10w40 and when it's cold it gets great pressure!
Cold it idles (in park) at about 60-70psi. After a drive and full warm up, it idles at roughly 25 psi.
After warm up, it cruises at 37 or so psi. Cold, close to 80 at cruise.
Just not sure why there's such a large swing. Otherwise, the pressure responds as it should. Rev and it climbs. It's not erratic or erroneous from what I can tell.
Is she just worn out? Am I safe at these pressures?
Thanks so much for any advice. I'm used to the older iron SBC. I never have pressure issues with my older engines and I'm trying to learn the LS platform quirks.
