Escalade side mirrors on a Tahoe LTZ!
K2 Kaiju
The Depths
Nice, how much?
Delivered after tax ~ $131 each after 15off75 coupon (they are listed for 135.xx). Hurry, cause that coupon expires today and is not good on every account (didnt work on my main acct); it appears on your main page when you log on. The mirrors are new, black, without puddle or camera. Seller is in dallas, and same one I got my heated wheel from so I got them in 2 days. Ill post after I get em on - waiting on 1 more switch...
Sent from my SM-T580 using Tapatalk
K2 Kaiju
The Depths
And done. Took about 2 hours - 1 1/2 doing one, and half hour on second (did passenger 1st) as always. Actually not very hard as projects go (easier than heated wheel), but I did do a lot of door panel removal on the gmt 900s (this is similar). No clips broken. The difference in visibility is incredible - way more than I expected; you dont need tilt to see your back up along the lawn. The power fold and memory function work since I replaced both switches, but turn signal was not hot. Now I pretty much have every feature I want (mirrors, fogs, heated wheel, rst grill) without the ones I dont (push button start, magnetic ride, sound dead, over chrome). Cost was 262 for mirrors plus about 75 for switches (I had some Amazon credit so I got them there, but they are cheaper elsewhere). Worth it IMO...b61a6ca375307b4f30654b5fae09d4c7.jpg5fb7e2a07fe62cd420d32a29348220d1.jpgceef61a231981f063fddb11485dbc8f4.jpg
Sent from my SM-G975U using Tapatalk
Christian80
And done. Took about 2 hours - 1 1/2 doing one, and half hour on second (did passenger 1st) as always. Actually not very hard as projects go (easier than heated wheel), but I did do a lot of door panel removal on the gmt 900s (this is similar). No clips broken. The difference in visibility is incredible - way more than I expected; you dont need tilt to see your back up along the lawn. The power fold and memory function work since I replaced both switches, but turn signal was not hot. Now I pretty much have the lux features I want (mirrors, fogs, heated wheel) without the push button start which is being blamed for thefts. Cost was 262 for mirrors plus about 75 for switches (I had some Amazon credit so I got them there, but they are cheaper elsewhere). Worth it IMO...b61a6ca375307b4f30654b5fae09d4c7.jpg5fb7e2a07fe62cd420d32a29348220d1.jpg1d21a5661b08e9e6dc434a137f09806d.jpg2d974fd4cd596ad4e08826af31c96621.jpg5af3cee064bbe97daf03aa671ef32931.jpgceef61a231981f063fddb11485dbc8f4.jpg
Not bad. I paid $220 shipped for mine but need caps. I went that way because those were the only ones I found without the blind spot indicator. Why is the turn signal not working?
K2 Kaiju
The Depths
Needs to be wired. I have a base LT without signals. Not really something I care about, and I will probably do a black vinyl wrap on them...
Christian80
You did not get the body harness from Matt? Mine is LT also but has memory seats and mirrors. For the price I believe the harness is well worth it, ads turn signal and puddle lamp as well as autodim.
K2 Kaiju
The Depths
I agree. If my new mirrors had puddle lamps, I would get the harness, but they dont. The switches give you memory and fold capability which is what I really wanted, plus the size which may be worth it alone. I didnt have to cycle it 3 times either - they folded on first try after I installed the switches...
cmatt
And done. Took about 2 hours - 1 1/2 doing one, and half hour on second (did passenger 1st) as always. Actually not very hard as projects go (easier than heated wheel), but I did do a lot of door panel removal on the gmt 900s (this is similar). No clips broken. The difference in visibility is incredible - way more than I expected; you dont need tilt to see your back up along the lawn. The power fold and memory function work since I replaced both switches, but turn signal was not hot. Now I pretty much have the lux features I want (mirrors, fogs, heated wheel) without the push button start which is being blamed for thefts. Cost was 262 for mirrors plus about 75 for switches (I had some Amazon credit so I got them there, but they are cheaper elsewhere). Worth it IMO...b61a6ca375307b4f30654b5fae09d4c7.jpg5fb7e2a07fe62cd420d32a29348220d1.jpgceef61a231981f063fddb11485dbc8f4.jpg
Nice! They look great. I like how the black caps blend with the side windows/trim.
BTW my harness will also enable the auto dim feature on the driver mirror in addition to turn signals, etc.
BlackYukon
I'm kind of a Retard
Does it matter what year the Escalade mirrors are for? I just ordered a set and one of them is for 15-17 Escalades and the other is for 18-19.. Will I run into any problems or are they essentially the same?
cmatt
It doesn’t. The main 18 pin connector will match up. The difference is the separate camera connector design. It’s square vs the more rounded one on the 15-17.
Staggered 02
Very nice upgrade. Those mirrors look great on your Tahoes. Price is very good as well. I purchased new ones when I color matched my mirrors. They are very pricey.
Well done gents.
rick3645
