2016 Suburban LT Fog Lamps install with OEM switch
nilleo
Hey all,
I wasn't able to find many (or any) cases where aftermarket fog lamps were added to a 2015+ Suburban /Tahoe (or similar generation) with the OEM switch, so I created an account here to share for anyone else that's interested.
Let's get to it…
Tools you'll need:
7mm socket driver
10mm socket driver
T15 torx driver
Suggested tools:
Clip removal tool
Electrical tape
Wire ties
Parts used:
Spyder FL-CTAH15-C fog lamp kit
GM headlamp switch w/fog part# 22752195
DEI 611T
Preface
I was hoping to use as much factory wiring for this installation as possible to keep everything as “factory” as possible, but mostly to avoid doing more work than I had to :). I dug into some schematics to see what the factory wiring was like and then proceeded to look for all the wires in the truck before getting dirty.
The good news – the factory fog lamp fuse was installed in the fusebox from the factory, woohoo. Also, the wire from the headlamp switch harness to the BCM was present at the headlight switch and at the BCM. The wire from the BCM to the underhood fuse box for the OE fog lamp relay trigger was also present at both the BCM and the underhood fuse box, excellent!
The bad news – the wires that are supposed to go from the fusebox to the factory fog lamps weren't in the wire bundle going to the front grille where they're supposed to be. I investigated further and found that the wire isn't even pinned in at the fusebox, way to cheap out GM!
Here's where the wire should go, notice how pins are populated to the left and right of the pin we need, but not where we want one :(
This setback meant that I would have to run my own wiring from the aftermarket fog lamps to the battery, and a relay to to control it all. I'll still be using the factory trigger wire for the factory fog lamp relay and just use that to trigger my relay.
Reverse engineering
The factory front fog lamp circuit works as follows – when you press and release the fog lamp request button at the headlamp switch, this sends a ground pulse to the BCM. The BCM interprets this pulse as a request to turn the fog lamps on, and if the headlamps are on, it sends a ground signal to the underhood fusebox to the fog lamp relay. When the fog lamp relay clicks on, it sends power to the front fog lamps and there ya have it.
Since I don't have access to a programming tool to enable the fog lamps feature on the BCM, it didn't do anything when I installed the new switch, as expected. No matter, I brought the 611T into the picture to replace the BCM's role in this party. So the 611T will take the momentary pulse from the fog lamp switch and control a latching on/off ground output that I will feed into the factory fog lamp relay wiring. Since the factory fog lamp relay wiring is missing at the fusebox and I'll be using my own relay, I'm pretty much just hijacking this wire as a way to get through the firewall without running any new wiring.
611T wiring
Black – to BCM brown connector, Blue - pin 22
Green – to headlamp switch, Blue/Gray – pin 6
Red – to BCM brown connector, Red/White – pin 4
Yellow – to BCM brown connector, Blue – pin 22
Brown – to BCM brown connector, Brown – pin 10
611T wiring explained
The module is “active” when the Black wire is at ground and the Red wire is at 12V+. I wired it up so that it only has ground when the parking lamps are active so that the fog lamps can only come on when the parking lamps are on, and turn off when the parking lamps turn off. The Green wire receives the momentary pulse from the headlamp switch to control the MOSFET that the Yellow and Brown wires go to. The Yellow wire is looped over to the Black wire so that it only has a ground input when the parking lamps are on as well. Lastly the Brown wire is what will trigger the aftermarket fog lamp relay on/off witch each press of the fog lamp switch when the parking lamps are on.
Interior Disassembly
Remove the fuse panel lid on the left side of the dashboard – it's the large plastic panel covering the interior fuses on the left dash.
With that door off, remove two T15 torx screws from the side of the lower dash panel as shown.
Next, remove another two T15 torx screws holding the lower dash panel from underneath, they should be easily visible.
Optional – use a small flathead screwdriver to unclip the hood release latch and separate it from the panel. You don't have to do this, but doing so will let you completely set that panel aside once you unclip it from the rest of the dash assembly.
You should now be able to unclip the lower dash panel. There are about 3-4 clips holding it on now, just get a good grip and pull towards the rear of the truck. These clips can be stubburn.
Once you take off that lower dash panel, you should now see two 7mm bolts holding the switch panel in place. Take those bolts off and pull that panel off – again, pull toward the rear. There are maybe two or so clips on this one. Unplug the harnesses and swap out your switch then set the whole thing aside.
The switch is held on with these clips...
Exterior Disassembly
Start the engine and turn the wheels all the way to one side.
Remove the 7mm bolts securing the felt wheel-well cover on the front bumper.
Get under the bumper and remove two 10mm bolts and a clip holding the felt cover on from each side of the truck.
Reach in and remove four 10mm bolts holding on the fog lamp blanks. (the left-most screw is out of view in the image below due to the angle)
Put the new fog lamps on, turn your wiring up through the fender and into the hood area, and put it all back together if you'd like. Don't forget to secure the wiring with a few wire ties to keep everything tidy.
Wiring
Headlamp switch
Fog lamp request wire (Blue/Gray)
BCM
X5 connector with parking lamp (Blue) and fog lamp (Brown) relay activation wires and a decent constant 12V+ source (Red/White) for the 611T note: the fog lamp relay wire may be Brown or Brown/White, take note of which color it is for you!
Underhood
Trigger wire for your fog lamp relay, should be the same color as you found inside at the BCM
Just in case it's not exactly clear from the previous picture where that harness is, here's a more zoomed out shot...
Good 12V+ source for your fog lamp relay
Appendix
For your reference, here's a rough block schematic of some of the circuits discussed here.
And lastly the final product
All lamps on
Parking lamps and fog lamps only
Fog lamps off
Angel87
Hey all,
Let's get to it…
Tools you'll need:
7mm socket driver
10mm socket driver
T15 torx driver
Suggested tools:
Clip removal tool
Electrical tape
Wire ties
Parts used:
DEI 611T
Preface
Reverse engineering
611T wiring
Wiring
Headlamp switch
BCM
Underhood
Appendix
All lamps on
Fog lamps off
Did your spyder Kit come with the chrome eyebrow molding? If so, is it the actual piece or is it double sided tape that goes over the existing eyebrow?
nilleo
nilleo
It did come with them. They're full replacements for the flat black ones. You unclip the flat black ones and the chrome ones just clip into the same place.
jem556
Florida
Finally, after all the replies from posters saying 'just wire them to such & such, or 'just connect this or that', this is actually an informative how-to for those who are not automotive electricians. Excellent job and thank you! You have provided more value to this forum with your first post than many have after hundreds...
Angel87
Where did you purchase the kit? How's the lighting quality on them so far? Is your foglight bulb led?
nilleo
nilleo
Picked it up from AutoAnything. I can't comment on the quality of the lighting since I don't drive it, this is my parents' truck - I'm only the family tech :). The bulb is an actual bulb, my guess is the stock fog lamp bulb that it should be. I've seen other kits that have the bulb in the housing and a pigtail coming off of it with the proper connector; this one has the connector right on the bulb. Aside from the lens being plastic rather than glass, I'd say this kit is a pretty decent OE replacement.
Angel87
Awesome. Thanks for posting the progress and results. I wish I was able to do this myself like you did but I'm not much of an "electrical guy" but I will take it to a custom shop in hopes they will do the same. Looks great!! When you search for the Foglights on autoanything, does it say it will come with the chrome eyebrows?
nilleo
nilleo
I don't think it said if they would come or not, I honestly don't remember. I bought it from their eBay store.
jem556
Florida
I just received this fog light kit from AutoAnything. The kit is Spyder branded (made in China) and the same that is sold by most other vendors and on eBay when a wiring harness is included. I am not impressed with the quality. I wouldn't have used the included chrome eyebrows anyway but they are plastic...similar to a cheap chrome license plate frame and as such, I'm sure would look like crap in a short period of time. As noted by the OP, the lens are clear plastic and these too will take a beating from road debris, bugs, etc., due to the mounting locations. More concerning to me is the glue joint between the clear lens and black plastic housing looks to be shoddy workmanship and likely to allow moisture to get inside the lens. I will be applying a bead of clear silicone around this joint prior to installing. If you are knowledgeable enough to build your own wiring harness, I would suggest you purchase the GM parts (lights / brackets). I would imagine that is what I'll be doing after a year or so after these have been in use.
Thanks again to the OP for a great installation write up!
DP121
Joel, where did you out the 611T after it was wired up?
toi
excellent write up
thanks op.
n idea how to do all that electrical stuff but i could show t to my mechanic friend who could understand more than i do hopefully :)
dcp17420
Do u have to press the factory switch to turn the fog lights on every time u get in car ?
nilleo
nilleo
Yes but that's by design on my part. In fact, it will reset when the parking lamps turn off. If you want it to remember the state, just connect the black on the 611T to ground instead of the parking lamp wire.
Ruikee
Any pictures of your connections from the foglights to the 611T and of it wired to the BCM? Great write up, i just want to get some visuals of what im up against.
Candielaine
