Post your lifts.
whitey hoe
Dont know if this has been posted but if everyone would post their lifts.
Lift type
Manufacturer
Trim/model version
Lift Height:
Weld or Bolton
Any modifications?
Review.
Pics
Im wanting to lift my 05 tahoe with autoride but theres to many to chose from and having mix reviews. I think this would help me best.
Lift type
Manufacturer
Trim/model version
Lift Height:
Weld or Bolton
Any modifications?
Review.
Pics
2005 Tahoe,2 1/2 keys,z72 springs,1 1/2 alloy spacers,extended bilsteins,and 285/70/17 coming on friday
MinnYukon
I'm doing the exact same to my Yukon. Just waiting on the shocks to arrive.
Duramax05blk
NH
3 inch body lift coil overs to level out with z71 springs. Ride height was not set in pic of coil over. 41 1/2 ground to fender excellent cv angles
Sent from my SM-G900V using Tapatalk
BigDaddy13440
Rome, NY
Where did you get the front coilovers from? I've thought about doing the same thing to help my 12 yr old torsion bars, but haven't been able to find any info anywhere, other than doing a full coilover conversion, removing the t-bars altogether.
Duramax05blk
NH
That is what I did. Took the picture before removing the t bars.
Used atomics lower mount with upper washers
BigDaddy13440
Rome, NY
I wonder if using the coilovers in conjunction with the t-bars would work?
I need new shocks as it is, I'm thinking about adding coilovers to take a small portion of the load off the t-bars... and then I could dial in the ride height/stiffness more precisely.
Duramax05blk
NH
If you don't want to eliminate torsion bars I would just suggest replacing your shocks with high quality adjustable shocks and adjust them to your liking
Flexx
Pro comp 2.5" keys up front, 1" rear. 285/70/17. Zero rubbing but there was some trimming.
Sent from my HTC One M9 using Tapatalk
06yukon619
Zone torsion keys
5100 Bilstein
4" spindle lift
3" coil spacers (rear)
Martinjmpr
Littleton, Co
There's a guy on this board who sells the coilover kit. He also sells reinforcing pieces for the upper shock mounts since they are now carrying all the weight that was previously carried by the T-bars.
He posts under the name Atomic and he has a big thread in the "Street Suspension" section of this board: http://www.tahoeyukonforum.com/threads/any-interest-in-4wd-front-coilovers-to-replace-tbars.57560/
It's pretty slick. I've been going back and forth on lifts and there's part of me that just wants to ditch the T-bars entirely and go with coilovers.
Then again there's another part of me that's cheap, and that's a BIG part of me. :D I also have to consider that my '04 'Burb is a bit rusty and that honestly I probably will only have it for maybe 3 years so I don't need to be sinking a ton of money into it.
But I like the idea of coilovers to replace the T-bars. If I had a really cherry Tahoe or 'Burb with low miles that I was planning on turning into an off-road beast or keeping for 10 years, I would probably invest in coilovers.
Duramax05blk
NH
The kit your are speaking of from atomic is what mine is. I elected to try using just the stock frame mount as i had read another member try it with atomics upper bushings and it has been holding up last i checked.
Duramax05blk
NH
if you dont mind me asking what is the ground to fender measurements..
Thanks
-Aaron
D Rollins
