roy72004
Let us see the final results man
I want one too
Here's more... Gonna try and finish it today.
Sent from my SM-G920V using Tapatalk
roy72004
Was only able to finish the stop and "latch", as well as mount it today. Had to work at getting the vehicles started. Neither my powerstroke nor the Tahoe would start. But my dinosaur 1964 Lincoln sa200 welder fires right up. Go figure...
GM iraqi
So far so good
But I see you replaced the whole rear bumper why didn't you try to build it on top of it
Will it work ?
roy72004
Check engine light. I will probably only change the front two. This is harder than I thought due to rust.
liberal usage of pb blaster and run the motor good to heat it up, they should come right out. That's how I've always done it.
roy72004
So far so good
Will it work ?
Because who wants that ugly pos stock bumper? I sure don't. I'm confused as to why you ask if it'll work? I'm building it to work, why wouldn't it?
GM iraqi
I'm sorry sorry for the misconfusion I meant will it work if you use the original bumper not the one you are building now
roy72004
I don't know, I could probably manage, but then all the welding would screw up the chrome and I'd have to have it re chromed or it would look like shit.
GM iraqi
Well I hope you finish it soon so I can see the final result and definitely it looks great so far
Cameron
Andalusia, Alabama
Plasti dipped the plastic pieces behind the back windows looks a lot better and did some regular check ups on things and need to check on a bank 2 pre cat oxygen sensor code I just got.
GM iraqi
Will you please add some pictures cause I think mine need some painting too
Cameron
Andalusia, Alabama
I'll have to get them after it quits raining I do have one of the one while painting them they were faded really bad much nicer now the plastidip leaves a slight texture but looks amazing IMO
roy72004
Finished the fabrication today. Now all it needs is paint. It's gotta warm up a lot more before that happens. Lol.
Drewphil
