NORCALSS 3/5-6 drop kit? JUST DO IT.
deepend
Kansas City
Installed the kit yesterday, took 9 hours from start to finish (2 of us working on it, also did brakes on all corners and painted all calipers and brackets). Looks killer, rides very good. Not nearly as stiff as I thought it was going to be. Was not too hard to install at the shop, just a lot of work. Anyways, here are some pics.
Before (36.75" and 37.5" from ground to fender lip)
After (32.5" and 33" from ground to fender lip)
Alignment specs (caster does not cause issues with tire wear)
Front (Belltech shocks, DJM lower arms, stock keys, severe duty upper BJ's)
Rear (Belltech shocks, DJM rear kit, 6" springs WITH 1" spacer, free travel mod is 100% necessary for this all to work, Spohn track bar. Relocating sway bar properly is CRITICAL, that thing has a sweet spot to avoid contact with other components)
Thanks to Tony for answer all my questions and offering a slick package to put the truck where i wanted it!
Bottom line, if you are thinking about it. DO IT. If you already installed this kit, and are having issues, something was not done right. I've never modified suspension before. Just took my time, read the directions with some supplemental info from Tony, and it all went together smoothly.
Any questions are welcome.
Hey first time posting im a newbie but ive followed you guys for years now. Anyways you tahoe looks awsome. How does it drive?
NORCAL SS
SUV SUSPENSION GURU
i designed the rear coils. My custom kit rides smooth its pretty much my feedback from years of doing them and i dialed in the best riding set up
NORCAL SS
SUV SUSPENSION GURU
just noticed that my kit has the extenders. Not sure why not there.
Fabior
Hey I love the truck came out great I have the same truck I was wondering what kit you use so that I can order it on eBay thanks
HawkMD
HawkMD
HawkMD
Can I ask what were the part numbers for the front and rear bell shocks? I know have to use a certain one for the lower DJM control arms.
NORCAL SS
SUV SUSPENSION GURU
Bump to the top for a great kit. If you go to instagram norcal_ss have been doing a lot of em lately.
This by far is the best 2-3/5-6 out and I can set up helper bags/full rear control arm kit/tubular uppers/beefy swaybars to really have a great cornering suv
donbalo
would this lowered set up fit on a rim and tire combo 285/35/24 . i currently have a 2/3 drop on 305/35/24 but wanna go lower
Bentley95
