rolfsent
Cincinnati
Well it looks like my Fuel injector is going out. Fuel pressure is leaking down, hard starting and misses when idle. Finally pulling the trigger on Monday and saying goodbye to $425!
noJeepshere
Bountyfull, Utahrd
Finally finished with the axle swap by installing the driveshafts and took it out to have a little fun.
sent from a slablet
Gzes
the drifting 2dr
Wichita tx
So the 350 had a a shit ton of blowby last night. Pretty sure it's a goner so now gonna search for a 4bt
chaingun427
OBS Mad Scientist
Mooreland, OK
Don't go 4 bolt, get a 2 and have splayed caps installed. It's much stronger than a typical 4 bolt
Sent from my SAMSUNG-SM-N920A using Tapatalk
Gzes
the drifting 2dr
Wichita tx
Yea cummins swap is what I'm gonna do. Gonna park it for a while and get ahold of the motor. Should be an easy swap
chaingun427
OBS Mad Scientist
Mooreland, OK
So aside from additional weight, why do a 4bt instead of a 6bt? i'm sure there's a price factor but any other reason?
KyLafoon
North Carolina
Installed new exhaust from catbacks back. Rolled Angle cut SS tips.
Sound is awesome. The old system was constantly falling off.
Got a rear hatch spoiler on order. I've noticed with 2dr cruising with windows down exhaust fumes backflow into cabin.
So, I bought a Rear Window Wind Deflector. Should be wicked.
Gzes
the drifting 2dr
Wichita tx
Dropped off the lade yesterday for a fuel pump. Gotta order an axle and put it on then I'll daily that til the k5 us back up.. well to me what comes first is what I will swap. 4bt 6bt both are still mechanical and simple. Might have a 6bt if my buddy talks with his freind and he wants to trade. Not worried about power I just want something that you don't see every day. Besides I'm tired of breaking things lol. I'd be mating to my 4l60 that's mild built so I don't wanna blow it up again
Gzes
the drifting 2dr
Wichita tx
Might be getting a Chevy solid axle. What t case is bolt on pass drop? Mines floor shift. I miss driving the war so might just get a cheap 350 for right now til I find a 5.9
noJeepshere
Bountyfull, Utahrd
A Chevy np208 is a bolt on transfer case. But it'll require cutting another hole in your floor for the shifter to be on the passenger side of the trans hump.
sent from a slablet
chaingun427
OBS Mad Scientist
Mooreland, OK
Any chance you have pics of the wind deflector and tips? Since i have barn doors now i've been thinking of getting one
Gzes
the drifting 2dr
Wichita tx
sent from a slablet
But that'd be a cable vss. Would have to convert to electronic. Since I'm body lifted I could fab up a bracket to retain stock shifter in the floor so not too worried on that part
Drewphil
