How to install E-Fans
livingez_123
Sandy, OR
Bought the fans from rock auto, and they are the higher blade count OE ones for an 08 yukon.
which fans did you go with from Rock auto, they show 4 different ones.
Dorman has 7 blades on each fan.
The Four Seasons has 9 on the left fan and 7 on the right
Captain_hi_c
Ga.
It is listed earlier in this same thread about post #60
I know mine are Dorman but IIRC the part # is 620653
TheAutumnWind
It looks as if this thread has not been bumped in awhile. I have an 03 Yukon denali XL and I am interested in E-Fans. Is PCM tuning necessary to enable this to function as factory?
Other than that concern this appears to be a fairly straight forward upgrade.
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
I have a new doorman efan for sale if anyone needs one! Just bought a cts [emoji7][emoji5]️[emoji91]
-Garry (01HDtahoeNJN)
YukonXL04
The Riverboat
Arlington, TX
Yes, you must have means of turning on the pins in the computer.
DPGDirk
Is someone running a higher output alternator or is everyone just running the OD pulley?
bottomline2000
Dallas, TX
I'm running a DC Power 270a alt. I don't think a stock alt can keep up with 2 fans running on high. It may be different if u are running full pcm control vs tapping into the ac compressor on the 02 and older models..
Sent from my SAMSUNG-SM-G900A using Tapatalk
YukonXL04
The Riverboat
Arlington, TX
I'm running the smaller pulley on mine. They gave it to me for free so why not. Also running a small amp setup so figured it would be beneficial to install it.
DPGDirk
Also, what is the latest year models of these trucks to salvage an OE set of fans from for my '03 Yukon?
I know it needs to be at least an '05, but what's the last year that fits?
Assuming all of the Yukon, Suburban, Silverado, Sierra models are the same?
Thanks!
bottomline2000
Dallas, TX
I have fans 2012 for an escalade. I dont think GM changed anything other than the blade design thru 2014. My part# is Dorman 620-653 from Amazon. .
bottomline2000
Dallas, TX
bottomline2000
Dallas, TX
I have a set of "factory" fans from an 05 yukon i got from a junkyard....high amp draw problem. Got a new set of Dorman fans from rockauto and the draw was not as bad..i think the factory fans were worn out..
The relays burn up because we don't have proper control of the fans in the older model trucks. Not sure it's a problem in the 03+ trucks. Trucks with factory ac don't cycle the fans with the compressor, they work on ac pressure and don't have the constant high load and can actually cycle on low.
DPGDirk
OK, so I called Dorman today. Since both the 620653 and 620654 will both bolt in to these trucks, I wanted to know what the difference was.
Apparently, the 620653 replaces the factory 5 and 7 blade fans. The 620654 replaces the 7 and 9 blade fans. The fan blades are the all the same on the Dorman replacements, but the 620654 spins at a higher RPM than the 620653 does to compensate for the fan blade count.
It looks like the 620654 has different motors than the 53 to spin the blades faster. This would explain the increase in amp draw with the 620654 units.
Now I just need to figure out which one I want for my '03 Yukon. The 54 would probably cool better, but may be more noisy. Probably should run a bigger alternator with that one, but still not sure if it would cause wiring or relay issues.
The 620653 should draw less amps, but don't know how well it will cool my rig when towing or running in really hot weather.
Why can't it just be simple....?
scottd
