DWebPro
Stevenson Ranch, CA
Figured out how to wire up the DRL/Blinker with switchback LEDs. I took pictures and will do a write up. Will post more shots later in the day when the sun goes down some.
Next is new headlight housings and a HID Projector retrofit.
Also in installed slim 12" sub in the back and an amp under 2nd row captains chair. Can anyone tell me what is best to use to cut the floor cover under the captains chairs?
https://www.youtube.com/watch?v=O6OjKAc9e0o
08grey
Drill a starter hole trace out the amp and use a jig saw.
Joew311
TX
I cut a piece of plywood and wrapped it in carpet to mount my amps. I made it fit perfectly so when the seat is down it's captured by the seat. I ran all of the wires through existing gaps and holes in carpet underneath the board and through holes I drilled in the board.
63Blackseries
Canada
Eibach swaybars coming on Wednesday!!
@Bruizza do you know if corvette servo work for all years? 2013+ with 6speed if they do i may probably order one too.
d-alex-l
You needed more bass? :wtf: I get more than I can handle with the kicker door speakers and a little equalizer tweaking..
bigmiker21
Senior Member
Central Ohio
Plugs and oil change today, had to order the oxygen sensor. Hopefully get that in so I can put my tune on.
Sent from my VS985 4G using Tapatalk
Bruizza
Nope I messed up and ordered it for the 4l60e. I guess the 6l80e is all electronic so there are basically not many parts for it.
DWebPro
Stevenson Ranch, CA
Yeah, I only have the stock Bose w/Navi in the truck. No bass at all unless the volume is turned up a lot.
Got it! I am still trying to figure a way to run the RCA/Remote from the passenger side rear door to the amp under the driver side rear captains chair.
Joew311
TX
Im not sure if it's the same as the bench seat mounts but you can pop the trim panel off of the back of the seat mounts and it will give you a decent place to bring the wires under the carpet. If I remember correctly there is a torx screw in the middle and some snaps around the outside.
DWebPro
Stevenson Ranch, CA
None of the carpet is separable and there are metal brackets to hold the captains chairs down.
Deephaven
The 6L80e just needs a tune to do the same. There is a corvette mod though that I am sure can be done. The paddle shifters on the Vette go direct to the transmission so there is no delay. On the trucks, delay. Pretty sure someone has hijacked that though.
As for the shifting characteristics though even a stock 6L80 can wallop you if you tune it to.
---------- Post added at 04:25 PM ---------- Previous post was at 04:24 PM ----------
Nice work Cody. Looks way better.
Phlipnstik
