Tom Joad
French V8 lover.
Yeah, I threw a protector plate in there. Wasn't going to go that far without it. New bearings, chain, snap rings and clutch plates to boot.
I just bought a BRNY from Adapt-a-case for mine.
, that's the norwegian car taxes for you...Looks great, didn't want to upgrade to poly bushings for the swaybar?Installed a CAI. Took a few hours but worth it. Also finally got my rear sway bar links and bushings. I can't believe dealer is the only place to get rear sway bar bushings at $20 a piece!
I see, cause the rear swaybar kit was $30 has zerk fittings to grease them too, rides alot betterI didn't, but the only ones I ever found were the OE ones. I probably would of, But I just couldn't find them.
ceramic pads on a hoe. this i gotta see and hear about. with slotted as well. are you sure the truck will even try to slowdown or will the ceramic pads in fact make it speed up even more?
Sway bar links in. New cross drilled and slotted rotors with ceramic pads in.
