07 up plug and play airbag rear system!!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
make sure your rear upper mount looks like the 07 upper mount i did in first post becuase if not you will need to notch the frame to make it work
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
just did my buddys truck 3-4 rear drop last night. Pulled his springs on his 07 cadillac ext and sure enough same mounts as the trailblazers
992dr
Eastern N.C.
Do you have any pics of them installed?
Also at ride height and layed out?
Thanks
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
No sorry had it on my old phone but lost pics. There are a few guys i set up on here also but nobody put up pics.
they lay the axle on the frame
992dr
Eastern N.C.
Hi Tony,
How's the performance aspect of this swap?
I have a PPV and it handles quite well for this size vehicle, I'd like it to handle as good but hoping for better results. I guess a lot of it depends on the shocks used, correct?
One more for yah, what is the overall drop with these? 3/4"?
edit Mine already has a small drop. How much more would these bags drop it at ride height?
Thanks
Sam
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Hi Tony,
Thanks
Sam
The bags at ride height are about a 3-4 inch drop (depends on what you like) but the problem people do is they dont make them independent so lots of air trasfer which is bad for cornering.
if you want a good riding set up thats adjustable the tbss bags are nice
992dr
Eastern N.C.
Ok cool, I have a Pedders set up which by there site says its a 2" drop.
Another 1 to 2 inches would be nice, it would level it out.
I'd most certainly hook them up independently, like you said better results.
Would these effect towing/hauling?
Thanks again
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
2015 has the same upper mount. So you can bag a 2015 rear for about 350 bucks which includes bags/rear hardware kit/my bumpstops.
Goodinblack
I Like Tacos
Dirty South
Someone who has done this post some pictures....
Not seen one yet.
Is this a bad mod or what?
No pictures on how this looks when done.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Not seen one yet.
brad postedin one of my threads i set him up. I wil have him come on here. He had the kildermans or wahtever set up on it and didnt like ride plus only like 2 inch drop at ride height. He put these in and said sits lower/rides better and best of all due to the tbss bag design you can tow 6500 lbs
Clean07Burb
I'd also like to see some pics of a NNBS SUV with these installed. Especially laid out...
I originally installed a 2/3 kit on my Suburban, but recently went 3/5. If I can get even lower in the rear using the TBSS bags and not have a ****** ride like most with 6" rear springs, I'd go for it. It certainly is cost effective compared to most bag kits, plus I could air out and lay it on the axle when parked, etc., if I'm understanding this correctly.
Tony, am I correct that these will bring the truck down about 4" at ride height, but aired out they will sit the truck down on the axle? Also, I'd want to control both bags independently and not tee both lines together to run them to the compressor. How do you control each bag separately with only one compressor? Do you install shut-off valves in each line so you can fill each bag separate from the other?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
My 6 inch springs ride great. No one tgat has my springs say they ride shirts so far.
The wireless air 72000 has independent control. Ride height will only be a 3 to 4 inch drop
Clean07Burb
Okay, so your 6" springs would ride better than these bags, so the only advantage to the bags would be the ability to air out when parked. Sounds like a trade off I'm not sure is worth it...I put a lot of miles on my truck with and without the family in it, so good ride quality is important to me. Might just have to stick with drop springs instead of these bags. Thanks for the info.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
What 5 inch spring arw you running? What does your rear drop consist of now?
Clean07Burb
Right now I'm more at like a 3"/4.75" drop on the Suburban. I'm running 5305's which brought me down 4.25" in the back and then I removed both the upper and lower spring isolators on both sides and that gave me just about another 1/2" for a total of 4.75" of rear drop. Also running shock extenders, DJM end links, Eibach front and rear sway bars, Spohn adjustable panhard bar, and trailing arm relocators that I haven't installed yet. Also have all seats in place and the spare tire even though its useless because it won't fit over the big brakes. Lol.
This is where the truck sits now. Don't mind the trailer. Its not bringing the rear down in this pic because the truck is on a hill which leveled the rear back out. Fender height is the same in this pic as it is without the trailer. Thinking it would look better a little lower...
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
My springs with belltech sp shocks and djm hardware kit ride better than what you have now. Thats,why I chose linear spring not progressive
Clean07Burb
@NORCAL SS
I've always been under the impression that progressive rate springs were better springs all around, including better ride quality? I also think my 5305's ride great and that they have always been known to be a great riding spring. I read tons of reviews on the 5305's by different members and one thing everyone was in agreeance with was that they offered a great ride. Seems odd that you're telling me that non-progressive rate springs are better than progressive rate springs. I'm not saying you're wrong, I'm just surprised because I've always thought the opposite was true.
Another reason I bought the 5305's was because I've seen you and other members post up that you could cut the dead coils off the top of the springs without affecting ride quality because they're just dead coils anyway. I figured if I couldn't get low enough on just the coils then I could always get lower just by trimming the dead coils.
BTW Tony, if you don't mind me asking, who makes your custom 6" rear springs? Is it DJM or Belltech or someone else?
---------- Post added at 08:16 PM ---------- Previous post was at 08:01 PM ----------
I'm almost at exactly where I wanna be in the rear. I'm at 4.75" of rear drop right now, but I'd like to get another 1/2" lower in the rear just to level the truck out perfectly. I think the 6" rear springs might bring the rear of my truck down a little too much. I just don't want that Cali lean. Lol. I hate when the rear is lower than the front!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
You said rode bad in other post so was going off of that.
The 5305s for what they are ride well but if you go lower my springs ride better. Also my springs carry load better with helper bags since no dead coils. Either way if you dint mind a 3-4 inch drop at ride height do the tbss swap
Djm makes my springs per my spec because it's a 250 spring run vs 500 for belltech
992dr
Eastern N.C.
I was always under the impression that progressive was more performance oriented to.
I just learned something new, hah.
Tony,
Can you order custom spring (linear) rates?
Also, what are your thoughts on drop control arms? Are there any alignment issues with them?
Candielaine
