Belltech 3 Inch only spring 00-13 gm suv
NORCAL SS
SUV SUSPENSION GURU
For those that want a 3 inch drop I hooked up with Roel at belltech and now offer the springs only. This is a custom spring not even in their catalog and will sit 1 inch higher than the 5305 springs.
$195 shipped to your door for the springs only. I would also look into extenders and or shorter shocks for the rear when using these springs. If you plan to tow helper bags would be needed.
Goodinblack
I Like Tacos
Dirty South
So it's a real 3 inch drop spring without spacers?
---------- Post added at 08:07 PM ---------- Previous post was at 08:06 PM ----------
Is this progressive?
How muxh?
b4z
Seems like these would have better ride quality and or suspension travel than the 4" drop with the 1" spacer, is that correct?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
its still had dead coils lke 5305 rides pretty much the same
crazycrew
Vacherie, LA
So, with my 1" spacer, I should be right at level for my 04 tahoe correct?
Sent from my SAMSUNG-SM-N910A using Tapatalk
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
depends on the front springs. Belltech has a 2-3 kit for 195 shipped that might be a better route to go
HeavyHoe03
