new member
Gtir007
2000 tahoe 4wd, biggest issue no power to the driver door/window /mirror- power lock works for all doors except driver side- broken wire or bcm? stumped- anyway pics-
sbubbaklein
House Springs, Mo
welcome looks nice.
I wonder if your door switch is connected to all of those circuits you might want to swap one out
G
Gtir007
Welcome. Good looking truck.
Plan on doing anything to it?
Thanks,plans - change the entire interior which I have already from a 2005 z71, electric fan, Bilstein shocks,2008 front brakes
---------- Post added at 09:42 AM ---------- Previous post was at 09:35 AM ----------
welcome looks nice.
Thanks- not sure about the switch,something is not supplying power to the mirror harness and the window motor harness/switch
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
From experience I'd say you have a bad window master switch, bad mirror motor (or switch) and bad window regulator. It's a 15 year old vehicle and the driver's side equipment is used the most. Also looking at the schematics for all 3 systems, they share only one common link; G203 Ground, but if you had a bad ground at G203, NONE of your windows would work from the master window switch.
boozer
Wichita, ks
wonder if the door has been replaced. i have an 02 and got a door off an 03 and the wiring harness was different. the lock would work but window wouldnt. changed the harness in the door now everything works fine
G
Gtir007
I changed the door harness, same result. I'm going to trace the power wire from the motor wire harness/ switch , it's a blue wire
Coatwolf
Eastern Virginia
Welcome, tons of info here, a wealth of knowledge - You'll find everything you need to get your rig straight.
G
Gtir007
updated pic- so much work to this truck and dont drive it that much- stuf i did 2/3 drop,bilsteins f/r,2015 yukon wheels,bbk,new brake lines hoses, hd hood ,cluster, intake- stuff to do change interior,esky vents,brake light, true trac diff,hd grill,z71 lower valence,fog lights,front end work,djm rear links,headers,rear seal
D Rollins
