sgtpoliteness
So, I noticed the brake fluid reservoir in my Tahoe really low. Found the master is leaking. Well, that explains my brakes that feel like poo.
Got the new master on and promptly spent 2 hours power bleeding, manual bleeding and running the output function for the ABS module. They feel awesome now!! Pedal travel
---------- Post added at 07:07 PM ---------- Previous post was at 07:05 PM ----------
Pedal travel feels like a normal car finally. I even got the ABS to lock up driving around the parking lot.
95escahoe
Tested out the posi a few days ago, gonna leave some better marks come spring time lol
knucklebuster283
Bethpage Tn.
Sense I bought the Yukon I've had no blinkers or the hazards, and the tilt would not lock. Today I got a whole column from the j yard and changed out the column. Now everything works as it should but, now it tries to fire on start up but will not stay running. I also noticed now when I turn the key to run, I get a security light on the dash?
2door2wheel
New York
its a passlock issue. its part of the column. when you swapped it out you made the security system angry. im not sure how they work but if you read about it you will find the problem
sgtpoliteness
I took some time and really scrubbed the front seats this afternoon. Wow! They were filthy.
95escahoe
Ordered new fuel lines, going to order the pump and get the gas tank shield powdercoated
BirchyBoy
Swapped the Kenwood in the Yukon for the JVC in the Blazer. Then, got the Yukon cleaned out and ready to sell.
BirchyBoy
Sold it tonight. Goodbye Yukon. You served us well in the 18 months and 18k miles that we had you. Treat your new owners well!
noJeepshere
Bountyfull, Utahrd
Went to the junkyard and got a manual transfer case shift lever for it, then went to my friends house where my axles are at and did some work on them to get ready for my axle swap soon. Then I hauled a couch (leather! $75!) home with it.
cent frum a smaert fone
noJeepshere
Bountyfull, Utahrd
Drilled some holes with a drill press, used grey paracord to stitch it up and stuffed some old rags inside of it to give it mass. It's too dark now for a pic of it mounted so I'll post one tomorrow.
Gzes
the drifting 2dr
Wichita tx
Trans is getting dropped Monday. Got a b & m shift kit and a rebuild kit. Wish I could have found a kit with kevlar parts but my job doesn't have them so... Meh
Phlipnstik
