rolfsent
Cincinnati
Had to climb over the back seat and pull the barn door panel off to manually unlock the door since my 2 month old actuator decided to die. Lock cylinder is also seized so I was SOL. Now to go back to advance and warranty this junk part out...
BirchyBoy
I need to find someplace that can test my key fob. It stopped working a couple months ago. I've replaced the battery and tried to relearn the system to no avail.
Gzes
the drifting 2dr
Wichita tx
Intakes on just got ta put the rest on and do water pump and efans fun day today... Gotta grind a bracke because it hits the intake now. Better be worth spending almost a g on these upgrades and tire
qukon 95
Took rear diff cover and comfirmed i will need a rear end, it's not making noise just to much play ,some shifting from a stop ,metal shavings on magnet and pitted gears. Moved my reverse light HID ballast to the headlight HID until i get the other set to my door , ballast is bad also painted the diff cover red to match the red air shocks
BirchyBoy
Just checking. And you hold the lock and unlock buttons down at the same time for at least ten seconds till the locks cycle?
Yes, nothing happens. I need to find a place that can tell if there is any signal coming from my fob. Home Depot used to have a receiver that could tell you if your garage door opener was working. I wonder if the signal/frequency is similar?
domer94
northwest NJ
if anybody is interested in my 99 ducks unlimited , please check it out in the classifieds. first 7500 takes it.
thanks
domer94
northwest NJ
Didn't you just buy that truck?
yes i only put 16k miles on it. however we now need something with a third row more and more. i found a really nice 99 burb with 107k miles im picking up. my wife got tired of riding in the cargo area when we have inlaws and cousins over...
landsoul
Just have them meet you wherever you are going. :D
Good looking truck and I know you hate to see it go.
Drewphil
