2003 Yukon
JesusArTorres
Tulsa, OK
This will be a slow and not-as-amazing-as-the-others build, but here it is nonetheless.
So far I've replaced brake pads, AC blower, alternator, LED interior lights and de-badged.
Before:
After:
Of course it looks a lot better. Will de-mold eventually. And apparently I need a 3M adhesive wheel? Hope to do more things soon!
NathanJax
Vacation Nathan
Jax, Fl
:popcorn:
Zumwalt
El Paso, TX
I have an 03 also and have not debadged yet, what was the turn out of the paint after debadging an 03??
JesusArTorres
JesusArTorres
Tulsa, OK
The paint was fine. After being covered for years I'm assuming it's in a better state than the rest of the paint.
There was some staining around the badges left, but I don't think it's nothing a good wash can't handle. I haven't washed it yet because I'm waiting to de-mold it first... Something I have begun!
tgui
Good stuff!
It sounds like your build is going to be a bunch like mine. (fix everything broken) ;)
JesusArTorres
JesusArTorres
Tulsa, OK
Hidden antenna mod!
I drilled a small hole onto this fender to fit a zip-tie in there,
then fed the antenna through this rubber stop.
---------- Post added at 12:44 AM ---------- Previous post was at 12:18 AM ----------
Also, I did this...
Test fit:
Paint: I was thinking of accenting the letters black, but I'm digging the all white.
All that is left is to clear coat it and buy some new chrome screws to replace the old ones.
Also, any idea how to fix this?
As you can see, one is bigger than the other which leaves the plates uneven unless I loosen to screw a bit on the left one. I can't take them off because that is what the screw holds onto.
NathanJax
Vacation Nathan
Jax, Fl
Nice. I like the what you've done so far :Handshake:
JesusArTorres
JesusArTorres
Tulsa, OK
JesusArTorres
JesusArTorres
Tulsa, OK
So that's why the DRL's don't work...
and the turn signals are white...
I didn't check the other side but I'm assuming they're the same.
JesusArTorres
JesusArTorres
Tulsa, OK
I got the the DRL's to work. I swapped the old bulbs with the bulbs from the tail lights since I'm not using them. They plugged right in.
JesusArTorres
JesusArTorres
Tulsa, OK
Today I smoked the 3rd brake light, replaced a door stop, and cleaned the interior a little.
Painting the brake light:
I like the way it came out. This will keep me satisfied while I wait to get the Esky glass and brake light.
The new (from a junkyard) parts I got: door stop and rear cubby lid.
It finally works now!
I replaced the front passenger door stop. It was popping, no more! This was my first time taking off the door panel. A little tricky I must say...
I guess I wasn't supposed to take the window switches off, oops.
Then I decided to clean the interior a bit. I focused mainly on the center console. After so many years junk just builds up everywhere it can.
"Gutted the Yukon," almost....
I foamed everything up and then rinsed it off.
They came out great! So happy that I was able to clean them that well. You can't tell due to no before shots. But believe me, there's no more junk built up on the screws or the edges.
JesusArTorres
JesusArTorres
Tulsa, OK
Finally got these done! It's a nice touch. This is the first time I've painted something like this, so it didn't come out perfect. But I'm glad with how it came out.
SRTH8R
Littleton, CO
Looking good. I will be pulling moldings soon as well. Except I am taking the easy way out. One of my body shop customer offered to do it for free as long as I still refer them. Plus I have a grille and fender flares they are going to color match.
JesusArTorres
JesusArTorres
Tulsa, OK
Thanks. And you struck a good deal, de-molding was a real *****.
SRTH8R
Littleton, CO
Yeah wasn't looking forward to it. Called the owner to see which eraser wheel he recommended, and he said save your money and bring to him. Can't pass that offer up.
Drewphil
