Free Travel Modification
Max
Mile High
Denver
Finally got around to removing the factory bumpstop bracket on my truck and damn it was a pain in the ass. Here is the factory configuration:
With bumpstop cut out via sawzall
Bit of grinding and elbow grease
Final product with rubberized undercoating
I am now able to drop the pressure in my helper bags to 2 or 3 psi and the truck rides just like it did stock. I plan to add a pair of lower profile bumpstops at some point though the bags do an excellent job of stopping the travel. Kind of a pain in the ass to do the mod but completely worth the effort.
rockymt21
wing addict
from the slums of shaolin
So does this allow the suspension to travel a further distance under compression? What part of the truck actually comes in contact with the bumpstop?
goozdenali
Banned - Bad dealings with members
massachusetts
its definitly worth it especially when its free!!! i noticed in the pic that you have a custom link on your upper control arm, is that being of any use since your not using the factory air ride shocks.
M
Max
Mile High
Denver
Those are shortened links I had back when the autoride still worked. I didn't put any bumpstops on since I'm running the helper bags, I'll just have to remove them later when it's bagged anyway.
goozdenali
massachusetts
whats your plan with bagging the rear, im working on mine this week. i know u always got something up your sleeve
M
Max
Mile High
Denver
Buddy is hooking me air ride tech kit that I'm gonna modify. I'm gonna call Bill at Fox for some black/chrome non-resi shocks at all four corners and run this digital interface for the bags:
Haven't decided on compressors I'm leaning toward an EDC even though I'm just bagging the rear. Probably a 5 gal tank and plumb a quick connect in case I want to use some air tools.
goozdenali
massachusetts
HAHAHA your a freak!!!! just like i said, always got something up your sleeve
---------- Post added at 12:39 PM ---------- Previous post was at 12:36 PM ----------
i got first dibs on your billsteins
Modded
That Guy
Damn Max I though you been done this mod!
So your gonna run Fox's in all four corners, gonna be unique on a lowered truck. Sounds like GMFS type of stuff.
M
Max
Mile High
Denver
Foxes are the shit! I've been running their stuff on cars/trucks for years they're just expensive.
Modded
That Guy
I know they're the shit, funny thing is I though about running them in the rear or my Tahoe when I was in the market for shocks but thn they weretoo expensive and I would not be able to show them off because the truck is too low lol.
I would do 5100s though if I was still shopping, comparable and cheaper alternative...
M
Max
Mile High
Denver
The problem with 5100s is they don't make any short enough for my truck. I love the bilsteins but even the HDs I'm running are a bit too long. Even with a hook up I'm still gonna drop $600 on shocks.
Modded
That Guy
Screw $600, I was thinking no way I will spend over $300 for all four thats whay I went Bilstein HD and Belltech SP.
Modded
That Guy
Yeah you prob. can RT, I saw that Raptor at InsideLine, looks hot in its own way.
BTW, Max where are the dust shields that should be on the Bilsteins?
M
Max
Mile High
Denver
I don't run boots on any of my shocks, they look buster :imo:
Modded
That Guy
Yeah they look buster when its the soft squueeze crap, mine are hard plastic that don't compress and shit and I prefer them anyday
NathanJax
Vacation Nathan
Jax, Fl
My free travel mod...
Max, how were you not ON your bumpstops? Before I did this mod, I was laying ON my factory bumpstops. I cut the bumpstops off, then I was laying ON my bracket. SO when I cut my bracket off, I now have about an inch before I hit my frame...
M
Max
Mile High
Denver
No idea, it didn't ride too bad with the helper bags at 5~psi and it may have sat on the lower profile stops but I honestly never checked. Rear sits at 31.5" now on the 30.5" tires with about 3 or 4psi in the bags. I think the bilsteins are too long now so belltech street performance will make their way onto the back once I get the other pair of cams to install on my ucas. Half temped just to build some bag brackets and weld it up this 5"-5.5" drop is NOT cutting it anymore.
NathanJax
Vacation Nathan
Jax, Fl
I've got something in the works too... I feel the same way...
D Rollins
