Gekko
Norway
Installed LED tails, had to file off some tabs on the Orange Bulbs to fit for turn signals uploadfromtaptalk1400088508742.jpg
Sent fra min C6903 via Tapatalk
Gekko
Norway
uh, those bulb sockets are not turn signal. they are the reverse gear lights.
I know,
According to the law, our turn signals must be Orange, so thats why.
It's the same issue in the front, both rows of the led lights in the front is wired for turn signals. And i have a 194 bulb in each of the Main headlamps, because It's defined in the law that park lights must be White in the front.
Gekko
Norway
For all time, as far as i know.
The rules on lights here are ridiculous no matter how you look at it.
qukon 95
Received my new bumper lights & side markers to replace my old ones.
95escahoe
Got a coolant leak coming from the heater valve area its only a few years old, hopefully its just a loose hose clamp
Sent from my HTC One X using Tapatalk
95escahoe
One of the clamps was loose on the heater valve let it run and it wasn't leaking so hopefully that is all it was
96redsport
Altoona, Pa.
Got the new headliner and visors put in..... Also installed the edelbrock shocks.
96redsport
Altoona, Pa.
Did you have the visors recovered? If so who did it?i need mine done but don't know anyone to do it. If anyone knows someone who can let me know please.
I bought these new from a seller on ebay for $160. I know I could have had them recovered for less but my old visors where twisting from age so I went with new ones..
---------- Post added at 01:13 AM ---------- Previous post was at 01:12 AM ----------
Edelbrock shocks, where did you find those?
Scored those bad boys from Ebay also from 2 different sellers about 2 months apart.... And might I say what a ride they provide on the highway...
Y2KpewterZ
Getting ready to drive down to Nags Head this weekend. Freed up some stuck caliper slider pins, greased all the ball joints..
Finally decided to bite the bullet on doing a trans cooler (as illustrated here http://www.gmt400.com/forum/showthread.php?18104-How-to-factory-auxiliary-trans-cooler-upgrade) I was weary about messing with a trans that has 300k miles on it, but I definitely dont want to burn it up on the sand.. bought the fittings, thread sealant, went to my local performance shop who had the B&M 70266 sitting on there shelf for months.. and it was sold. Guy said someone came and bought it yesterday. Figures.
BirchyBoy
I did that mod this past weekend. Not too bad at all. Make sure you mount it close to the radiator or else you'll have to start over....like I did.
Y2KpewterZ
Racked up almost 600 miles on it in a day.. sittin pretty on the beach though
Forgot to mention I got 20.2 mpg out of it.
95escahoe
Great pic, love this truck
---------- Post added at 12:07 PM ---------- Previous post was at 12:06 PM ----------
Changed the plugs on the driverside and put on the Moroso spark plug wire looms, just need the new wires to come (getting red ones and will look mint) gonna do the pass side latter
Y2KpewterZ
Thank you. Those valve covers look awesome
Full chassis cleaning after the beach.
And got started on doing my B&M Super Cooler mod. Little set back with the lock rings on the quick connects.. ended up losing one and couldn't get the second one off. I actually did one side with out even removing the lock ring and line, so, as opposed to the "how to" thread on GMT400, I think you can get away with doing this without even fooling with those little bastard lock rings. Your knuckles will appreciate it.
95escahoe
@ Y2KpewterZ no problem and thanks
wildwest450
Replaced the fuel pump relay after a no start situation, the cheaper solution actually worked for once.
And I had just filled my tank up, suck on that Murphy.
NjA4207
