Taylor Cable 11011 - Taylor Vmax Manifold Intake Spacer's?
saif najd
Hi every one
I am asking about the Taylor Cable 11011 - Taylor Vmax Manifold Intake Spacers if any one ever used this part and what should I expect out of it and is it worth it?
What They say about it:
Description: Maximize your car's potential with these Taylor Vmax manifold intake spacers. These spacers are constructed of billet aluminum and allow a larger volume of air inside plenum on late model intake manifolds. More air means more power and Taylor has dyno tested these spacer to ensure positive gains in both horsepower and torque. All of the necessary hardware and step by step instructions are included to make installation easy. Help your car breath the way it wants to with these Taylor Vmax manifold intake spacers.
Now what do you say about it?
Sent from my GT-I9505G using Tapatalk
SunlitComet
OBS Jedi-Do Good
unknown at this time.
gpracer has installed one. i have not and don't expect to as it would make it very difficult to install some CAI units with out them hitting the hood.
saif najd
saif najd
OK! So new problem :(
I see that it results in 21hp+ so that's great but I think there is a price to pay!
retorq
Kingman AZ
21HP gain vs you need to slightly modify your ricer CAI ... it's an easy choice.
autolover3
Bismarck/Wahpeton, ND
If you got money burnin a hole in your pocket and want a few extra ponies and want to deal with potential clearance problems.. I'd just go for a marine intake and allow for upgradeable injectors and no internal spider assembly :/
saif najd
saif najd
That's a lot of work, keep in mind I am at a low resource market so doing the spacer for my situation is easier because I cannot find any human to program my 98 Tahoe ecu
SunlitComet
OBS Jedi-Do Good
could away buy the software/hardware and scan it yourself and send the file to blackbear to modify for you. or just have them program a spare pcm and send to you.
saif najd
saif najd
Very good idea (the spare PCM) I well look at it
TigerEyz3
Slow and Steady
TN
I've had the VMax installed for several years, and there is a noticeable difference to me... Butt dyno says that the TQ is better compared to pre-VMax installation.
In the interest of full disclosure, I installed the VMax spider at the same time that I switched from the factory spider (with poppets) to the MPFI spider (injectors at the cylinders)... could be a combination effect.
My personal opinion is that the VMax modification was worthwhile in my application - spirited daily driver and light-medium towing.
saif najd
saif najd
Wow, great that is exactly what I was looking for.
Thank you so much for sharing
Phone Man
Long Island NY
I also have it but had issues with the fuel lines blocking the #1 spark plug wire at the distributor. they have to be bent out of the way. but it also pulls the rubber fuel lines that come from the fuel filter and return.
Candielaine
