95escahoe
These came today
Sent from my HTC One X using Tapatalk
retorq
Kingman AZ
Those won't work on your setup they are for Vortec heads only, they won't work on a TBI head. Since I have a Vortec swapped TBI you can send them to me and I'll put them to good use.
95escahoe
You 100% sure? Cause Jegs says they fit and another member on here has them, it says 87+ small block chevy on the box and Jegs lists it as fitting a 95 Tahoe
BirchyBoy
I think I found what you bought and it says they're for '96 and older. I thought about some for my '99 but I guess not :-(
95escahoe
He was just joking around about what he said, ya they fit mine, look up proform on Jegs they might make another model for yours
retorq
Kingman AZ
The issue is the baffling of that large hole (or lack there of vs what you got now) and the stock hole sizes. You can make them work, they will physically bolt on, you may need to find/change grommets, PCV routing, etc.
95escahoe
Got one of the proform valve covers on driverside one I am going to need to remove the alt I think, pretty clean for 255k had to remove very little sludge
retorq
Kingman AZ
I can get mine on and off without removing the alternator ... I have that big AD244 too.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Well no brake work this week but for sure the extra help I will get said for sure on next Saturday. Hope it don't rain. In a parked it inside the driveway gate. If I can get off my but I will try to clean it up inside. Tooling piled in the cargo, back seat and front seat.
---------- Post added at 01:47 PM ---------- Previous post was at 12:54 PM ----------
Sorry if I am making you hydro conversion enthusiasts wait so long for my results. Just so you know I will be doing the booster booster MC, rear brake rebuild and now as broke as I am the front pads. Also de-film my slotted rotors.No brake lines will be touched. in this work. Can't afford it right now.
chaingun427
OBS Mad Scientist
Mooreland, OK
used a 4x6 piece of 1/4 inch steel to repair my front seat, lets see that little bugger break on me now! also removed both rear door latches, dremeled the rust off and greased them (thanks to Sunlit for the tip on the white lithium grease) and installed new 6.5 inch speakers in the rear doors.
RynoHarris
Write up? Lol
---------- Post added at 03:57 PM ---------- Previous post was at 03:57 PM ----------
On the seat I mean....
chaingun427
OBS Mad Scientist
Mooreland, OK
I posted my method up in the interior forum. I got my hands on my new console today from a 99nbs pickup and i'm testing fitting around the floor mount 4wd. This is gonna be easier than i thought in some ways and a bit harder in others
Chevrolado
Redondo Beach, California
Finally found the blown fuse that was causing the issue in my power door locks and my rear speakers not functioning!
It's only been an entire year without them.. :chicken:
curbud
