Where exactly is the stock amp in an 03 Yukon wiht Bose?
yooformula
Milwaukee, Wi.
I was thinking about bypassing the stock sub and using those leads for a line input on an amp/sub combo. I just need to know where the stock amp is so I can just work there. thanks!
NathanJax
Vacation Nathan
Jax, Fl
Should be underneath the center counsole towards the front... (if I remember correctly)
kses123
kses123
Raleigh, NC
Right under the console. Under the storage part.
There is the sub, on the left. Right thing is A/C vent for the pickup trucks.
jESse
i like cheese
michigan
does anyone have a wiring diagram for that amp? i'm looking to add a sub into my factory system and plan on splicing a line out converter into the factory harness and want to tie it in with the factory sub wire. thanks
JKmotorsports
Austin, TX
If you remove just the cupholder tray, you can access the wire harness for the amp and catch the sub wires right there w/o having to remove the entire console. There will two sets of wires since it utilizes a dual coil sub.
jESse
i like cheese
michigan
any chance someone could take a pic of where that plug is at and maybe if they know wire colors? seems to be alot of stuff under there and i want to make sure i get it right. thanks
OmarR
Indianapolis, IN
The plug is directly underneath the cupholders. It's the only big plug down there, you can't miss it.
Subwoofer outputs:
Left (+) Dark Blue/White
Left (-) Light Green/Black
Right (+) Dark Green
Right (-) Light Blue/Black
skruzman
Subwoofer outputs:
THANK YOU for this post...this happened to me last night and this was the fix...15 seconds!
AdrienR
