96 yukon with 20" lift and 46" tires
Gzes
the drifting 2dr
Wichita tx
You can get 4.56 that's probably what I'm gonna run for 37s when I do my sas
That's what I was thinking of doing, but the guy I talked to said I might want to consider 4.88's if I even plan to get a bigger or heavier tire.
I tow a good amount so I would hate to be under geared (dealt with that in my last truck and it sucked) and for just one size it would suck to have to pay to do it all again.
Sent while day dreaming...
DaRosa218
The Dude abides
Modesto, California
Wow, I had no idea. I am seriously re gearing now! I'm stock 3.73's with 35's getting 9ish (uncorrected speedo). Now the problem I have is what gears to go with.
I have 35x12.50 on the Suburban with 4.56:1 gears and get 16-18 out of her. Not to mention she'll spin the tires off the line. You should see the looks on the rice burners faces when I spin the 35's from a stop light.. LOL
Gzes
the drifting 2dr
Wichita tx
True yea I also tow alot in my2dr. Haul cars in from other states close by or in town so bigger gears are gonna be better. Get the gears you want and let us know how it works for you ill be curious to know :)
SouthernHoe
Thats awesome...sent you a PM.
_Dylan_
STAY FROSTY
OK I'm am needing a drop pitman arm. I've asked around at a few shops but they tell me they don't make one. what parts change so i can get rid of the steep angle on my steering arm. and i don't wear out heim joints.
Some searching says a 79 f150 arm will work, like this:
http://www.wfoconcepts.com/pr/Superlift-1104-Pitman-Arm-Chevy-tie-rod-taper/3163/3360/3362
Part of the problem is the drag link is at a different angle compared to the track bar. When you hit a bump the axle shift slighty to the passenger side. Since the angle is greater on the drag link as compared to the track bar, it's going to kick the steering to the right.
I would suggest using a drop pitman arm, high steer on the axle like this:
http://offroaddesign.com/catalog/Dana44crossover.htm
and track bar that is equal length and at the same angle as the drag link.
whitemike1985
whitemike1985
thanks that helps a lot i am going to check that out and see if i can get everything swapped to help my steering. thanks
CKendrick
