L31 Vortec with TBI - Is it worth it?
Chevrolado
Chevrolado
Redondo Beach, California
how did this setup work for you? i believe i am in the same situation as you were. i dont need nothing too fast but i would like something that would hold up for trail riding or a bit of off road...i have a 95 yukon z71 5.7, not to sure one how to go about rebuilding my 350 tbi...
I didnt end up going Vortec L31 (original idea of this thread).. I went pre-vortec replacement and bumped it up into Edelbrock goodies instead. Much easier to deal with the standard 95 gear rather than swapping all of the computer and fuel provisions that changed from 95 to 96 Vortec.
And yeah, just use your existing TBI like Sunlit said. :)
Monstar_est87
City of Angeles
Very sweet swap... Sunlit definitely pointed in the right direction... Ive got fam in LBC I'd definitely like to check out ur rig next time I'm in ur neck...
retorq
Kingman AZ
You don't need to swap everything, you can swap just the long block and run a different intake.
SmittyJ
Hey what part number of Edelbrock top end kit and TB did you use on your build? I have a 94 K1500 and I've been thinking about the exact same thing as you. I wanted to go with the L31 because it was vortec and has hydralic cam but if I could just do a whole new L05 that would be awesome! Thanks in advance!
Chevrolado
Chevrolado
All the part numbers I used were from this graphed pack:
They dont offer the exhaust any longer. So I just got the cam, heads, and manifold and then they gave me a piggyback chip for my ECM to match the new parts. :)
Good luck.
saif najd
Wow really woooow great work no I am sorry amazing nice..
By the I have a friend who is looking at a a TBI 350 engine he has a 454 engine or I should say he did the swap to the 454 carburetor but the engine heat is great so after much of repeating how great is the 350 now he is willing to swab back but I have to help him on how to get more (safe) power out of the carburetor 350 engine or TBI
the truck is a suburban 1500 I think 98 model (last year foe the square body models)
Sent from my GT-I9505 using Tapatalk 2
SunlitComet
OBS Jedi-Do Good
unknown at this time.
True about the edelbrock exhaust but LMC is selling the HEDMAN headers equivalent for the tbi at about $650. Find it cheaper somewhere else if possible.
Chevrolado
Chevrolado
Yeah I ended up ordering a set of SMOG legal (cause CA is crazy that way) FlowTech shorty headers for it. I like em.
Bought the standard black ones for around $300 or so. Then paid another 250 for ceramic dipping coating.
Now I need to figure out how to keep my header bolts from backing out as often as they do.. Hah
JarRod73
I just put a 97 vortec in a 90 tbi. Used a jegs intake and adapter plate. You dont have to upgrade fuel/chip if your ok with 230hp. I upgraded my fuel pump(took the 97 and put in the 90). And put a neg spring in my regulator. I'm waiting for my chip but the truck still runs ok. After the chip I should be making around 400hp. I put all the sensors from the 90 in the 97 motor and left over you dont need. Timing is hardest part to me. No timing mark on vortec block so I had to make sure I lined up my distributor really close. It can be done just need the whole donor truck pretty much. I had to use parts from the donor and parts from the truck I was putting it in to make things right.
dizhai
