L31 Vortec with TBI - Is it worth it?
Chevrolado
Redondo Beach, California
Hey y'all. So I've done a bunch of research on throwing an L31 Vortec motor (96+) into a 95 OBS and bolting up the GM Performance manifold that converts the standard TBI to the Vortec heads. It looks like there is a bit of modification needed as well as updating to better fuel delivery and getting a custom chip built to handle the new fuel delivery/air delivery with the stock 95 ECM..
So after all of this... is it worth it? I mean, why not just rebuild the 95 TBI motor, mod it to achieve a little extra umph, work through the ultimate TBI mods and get it setup pure and call it good with a brand new 95 L05 under the hood?
What's your thoughts? For a person who isnt racing, just some light offroading, trail runs, exploration type vehicle. Reliability, longevity, with a little bit of power to pull up the hills and through the dirt.
I'm about to put a new motor in this 95 Tahoe of mine, just cant decide if I want to go through the extra work needed to swap in the L31 Vortec or if I should just build up a good standard L05 and drive it until the cows come home..? Any help, advice, opinions, and all that is appreciated! :)
SunlitComet
OBS Jedi-Do Good
unknown at this time.
unless the manifold is carb exempt forget it. however if you want to put a vortec complete power-train of the same drive type from engine compartment to tail pipe that is completely cali legal and leaves you open for other possibilities. you would have to grab all the vortec harnesses. and may need to make some minor rework on the bulk head connector but the harnesses should be easy to do. of course the quickest and maybe cheapest is to just put a new L05 block in. http://www.jegs.com/i/GM-Performance/809/12568758/10002/-1
Chevrolado
Chevrolado
Ah, I was under the impression that the manifold would work fine for carb issues. I think it still retained all necessary CARB legal options that you could carry over from a 95 and still be able to use it all the same on the top but basically just swap out from heads down to newer type. :eek:
Oh and thanks for the link. That is the L05 I was looking at. I'm at the debate portion here where I need to decide.. L31 and prepare myself for modifications and computer chip and such to get it to work CARB legal and to run properly, or L05 in it and update the top side to make sure I have a smooth running fresh new motor..
Yes it's worth it.
Have you done it? Know people who've done it?
SunlitComet
OBS Jedi-Do Good
edelbrock did have a power pack that had heads intake and came that was all carb legal all the way up to 1995. very pricey. lmc charges a sac for it.
Chevrolado
Chevrolado
Yeah I was looking into those last night as a possible option of bringing up the power on the standard 95 motor but if Im reading correctly, the cam used says not for computer controlled. I have a feeling they arent CARB/SMOG/CA Emissions friendly power packs.. :nono:
Chevrolado
Chevrolado
SunLit.. you are a life saver! When I get this new motor all situated.. I want to meet you and buy you a beer or two kind sir!
The Edelbrock 5.7L power pack looks like it will be the perfect setup for what Im doing. I gathered all of the part numbers and setup and walked into my speed shop that is building my motor and we ran through everything, they called their Edelbrock contact directly and got all the info and they are flashing me the free computer chip to match that whole pack of heads, cam, and manifold and we're going standard 350 on bottom end. Placed the order and we'll be getting started next week!
Thanks again man. Finally worked it all out with the help of your linked direction above. This option will work out for what I want WAY better than dealing with the L31 swap and modifications/hassle for the time and money I have. :D
Chevrolado
Chevrolado
keep us informed.
Hey man.. I definitely owe you a beer. :cheers:
5 months later... Fresh new motor with the said Edelbrock top end pack finished and installed. :D I'm a big fan. Still working out a couple little kinks and just about to finish my initial 500 mile break in process so I haven't truly put it through it's tests yet but I love the low end torque so far. :High 5:
350 new block. Edelbrock Performer Heads, Performer-Plus Cam, Performer TBI Manifold, Flowtech ceramic coated headers, Edelbrock piggy-back chip (they provided for free when buying the combination of the whole heads/manifold/cam pack). All CARB EO numbered and SMOG legal for CA use. :)
I just wanted to extend a special thank you for pointing me in a direction that definitely worked out great for me.
:signs1:
SunlitComet
OBS Jedi-Do Good
Very well done. Let it be an example to others in Cali who are interested in better performance and still be completely legal. And to disbelievers as well who say it not worth it. Make a record of all you CARB E.O. info to keep in the truck for inspections. Or label maker them right there on the fan shroud. Maybe you can find a Whipple SC to top it off.
_Dylan_
STAY FROSTY
...or move out of commiefornia and put whatever the hell you want under the hood of your car
Chevrolado
Chevrolado
Thanks SunLit! Yeah man for sure. I'm going to get it all posted up on the fan shroud soon. I have a full packet of all the paperwork and stickers in my glovebox. :D
Dylan; yeah that would be nice! However then I wouldn't live in CA anymore! The trade off doesn't appeal to me. I love CA too much to leave just to be able to put whatever motor I want in my vehicle. :)
firstZ71yukon
how did this setup work for you? i believe i am in the same situation as you were. i dont need nothing too fast but i would like something that would hold up for trail riding or a bit of off road...i have a 95 yukon z71 5.7, not to sure one how to go about rebuilding my 350 tbi...
canadiandux
