TheBlueBeast
The newest body style looks like rotten vomit. This does nothing but convince me that my OBS is one of the best looking designs yet.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
The farthest I will go in style would be likely 2006. After that the lights start to get weird for me. But if the can become some very nice hid projectors I might look into it.
95BlackTahoe
Edinburg, PA
Added the Jeep XJ steering shaft onto mine...Didn't take long at all, and was very worth it...Makes a big difference!
Shawn
Gzes
the drifting 2dr
Wichita tx
Tell me more bout the steering shaft upgrade. Might look into it when i do my sas
Gzes
the drifting 2dr
Wichita tx
Thanks. Ill probabky do it later if i start to see some slop in the wheel. Mines fine right now
BirchyBoy
Plugged in my new BT OBD2 adapter and set up the Torque app. It went well but the trans temp signal wasn't available. I need to see if I can enable it.
Figured it out after doing a little searching. I had to enable the GM specific codes and all is well now.
BirchyBoy
My key fob had stopped working within the last few days. It is a 3 key, no alarm, and they are a bit on the expensive side. I had replaced the battery within a month but took it apart again to see if the batter had slipped or something.
I removed the circuit board to see if I could activate the buttons manually and found that there was a film of oily stuff between the keys and the board, and the black backing on the keys was pretty degraded. I dried everything off, put it back together, and it is working 100% again. Well, except for the rear doors. I think I need to clean the contacts for that.
Anyway, I ordered a new case and key pad. Not sure what the oily stuff was. Any ideas if there is supposed to be some conductive material between the rubber pad and the circuit board?
TahoeLimited
Fountain, CO
Speaking of key fob function...the other day I pressed the small button on the bottom, wondering what it does. I kept hearing something clicking below or inside the dash, but couldn't figure it out. Anyone have any ideas?
BirchyBoy
Mine only has 3 button: Lock & Unlock (across the top), and 2x (bottom right) for the rear doors. If yours has a 4th button it should be for the alarm (assuming you have it).
_Dylan_
STAY FROSTY
Just 15+ years of ass sweat and gunk that builds up in there. Clean them again and see if it helps any.
The rear barn doors can be temperamental though. They don't always close just right and don't always unlock with the key fob in my experience.
You can also solder a small piece of wire to the antenna to increase the range which I recommend. It helped my remote a bunch.
http://www.gmt400.com/forum/showthread.php?5854-WRITEUP-GM-Remote-MOD
TahoeLimited
Fountain, CO
Mine is like yours...3-button, just like you described. I thought that the lower-right button might open the rear door, but it did not. It's when I pushing it at the rear when I heard clicking coming from the front, which I later found to be under the dash.
BirchyBoy
Mine works sporadically, but it has to be pushed twice in quick succession for it to work at all. I'm thinking the actuator in my rear door may be failing because I can hear it trying to work but sometimes it does not.
SunlitComet
OBS Jedi-Do Good
Finally ordered two new magnaflow Cali converters for my vehicle. Just need to get the actual headers of my tri-y's on and 4 blocks and $300 later, maybe next week or week after, my whole system will be complete, Cali legal, smog happy, newly sensored and finally done.
SunlitComet
OBS Jedi-Do Good
I have had the cat back in since Dec. I have had the headers floating around the states with me for 11 months now. The ceramic coating and the cats were holding me up really. The coating I got done in may I think.
BirchyBoy
Have you noticed a difference with the cat back system?
SunlitComet
OBS Jedi-Do Good
Yes. As I have mentioned before the sound will be different then what you expect it might be. While the outside may seem the same or louder as a 40 series muffler the kit is quieter inside the cab. And getting the kit is a better for the suv because it is tuned to help the power band overall and not just sound loud.
Drewphil
