slipping
Rosamond, CA
While its down, picked up this to scoot around
Gzes
the drifting 2dr
Wichita tx
Nice hatch vtec? Those are fun lil bastards. I did the nbd master cylinder
slipping
Rosamond, CA
I Dont think VTEC was my buddies and he said guy before him put the 1600 Japanese motor in it. Quick little thing. My first stick so its been a learning experience
Gzes
the drifting 2dr
Wichita tx
Nice they are very easy to drive and im betting you got a cable trans. Take a pic of the valve cover and ill give ya some info.
MC153
Finally got some parking lights that didn't crack around the screws when I snug them. Don't buy Eagle Eyes lights, pretty cheap.
Gzes
the drifting 2dr
Wichita tx
You can always plastic weld the cracks fixed. I had to rebuild the screw holes on my dash trim with plasric weld and installed it today
MC153
I thought about it but I figured if I bought the lights new they shouldn't crack the first time I use them.
Sent from my HTC One V using Tapatalk 2
MC153
yea def lol. cant wait for my fogs to come in
Which ones did you get? By the way I like the Edelbrock air cleaner on your truck, plan to stick one on mine soon.
Gzes
the drifting 2dr
Wichita tx
thanks. well i got fogs for my sol with a em1 conversion lol. gotta put my bootleg kc lights on my hoe tho. gonna put them on my guard and gonna put some on my basket. the eddlbrock cleaner only ran me $30 just get a 14 in and 4in i have 3 in filter and way to low...
MC153
Nice, someday I wanna get a bull bar with some KCs. I'll remember to get a 4 inch filter.
Gzes
the drifting 2dr
Wichita tx
Yea thats nice i had a bull bar with 2 lights on the hoe. Its my avatar pic
oldbrowntruck
Michigan
Pulled the front axle
My project is the front end of the engine. Water pump, tension pulley & belt, front cover, chain and gears. It started because the front seal was leaking too much.
I pulled the axle to get at the oil pan. I'm putting a new pump in while it's apart.
I took some pictures to prove to a buddy that it was easier to pull the axle than to lift the engine.
Smooth job.
qukon 95
I need to replace my efan motor it's got a howling sound bearings going
Bad.
2drhoeon4s
i did all this a few days ago but Im ADD haha so i forgot to post...
NEW Radiator
New IAC
PLUGS
new rotor
cleaned up the wiring on my remote start/alarm
washed her
got a little surprise show feature for when i do night time car shows!!
Oil Change
Coolant Flush
and a little engine bay wiring cleanup and re/tape the wire looms..
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Bad.
Nah, it just trying to be like the old clutched unit.
---------- Post added at 08:52 PM ---------- Previous post was at 08:28 PM ----------
Had to order an upper oil cooler line. Starting to make a mess everywhere not to mention the smell
2drhoeon4s
no kidding.... mine is developing a leak..... not gonna be fun trying to get to the bottom where it attaches...
TahoeLimited
Fountain, CO
What did I do to my OBS Tahoe today? It's more of question of what I did "at" it. Which was looked. I looked at it, alright? More specifically, I looked at the gauges display panel and eyeballed the illuminated green driving-lights-on light. You know...the indicator light that gives a subtle suggestion that the headlights are on? Then I scratched my head (in my mind), wondering why in fact my headlights were not on. Included in my ponderings of life, electronics and indicator lights was the consideration that my headlights work quite fine when the knob is turned, normally used to help one get their OBS Tahoe down the road in post-sundown situations.
Am I mistaken as to what that indicator light is trying to tell me?
---------- Post added at 08:56 PM ---------- Previous post was at 08:37 PM ----------
"daytime running lights" is what I'm assuming the dash light to be indicating.
Gzes
the drifting 2dr
Wichita tx
My silverado used to do that. When I turned headlights on it would turn off tho. Never found it what it was
noJeepshere
Bountyfull, Utahrd
It's the daytime running lights indicator, either the module is bad or somebody pulled the fuse (like I did) disabling the drl's but keeping the indicator as a reminder that my headlights are off.
cent frum a smaert fone
Hodmjstone
