Ebay reverse camera install write-up
dropmech
Puddle Pirate
Coral Springs
Here's some pics of the install I did for the ebay reverse cam. Let me know if you have any questions that weren't answered here.
Step 1: Remove dash cowling by firmly pulling straight out on the boarder.
Step 2: Remove the blanks from the bin. I just ended up putting the TC inside the dash. I never turn it off.
Step 3: I removed the bolt holding the AC vent so I could get to the clips holding the blank in a little easier. Then I removed the blank bin.
Step 4: I installed the camera to the license plate. I ended up taking some diagonal cutters and notching out a small channel at the top of the plate to allow a little more wiggle room for the camera cable.
Step 5: Route the camera/power wire. I took the wire from the camera behind the bumper and up through the hole by the body mount. Then I routed the wire up through the cavity for the LH taillight and end cap. The day light in the second pic is looking up from under the Hoe into where the taillight normally is.
Step 6: I spliced the wires directly into the reverse light power and ground. I didn't use a fuse anywhere, just spliced it up.
Step 7: I routed the rest of the wire through the vent flaps under the end cap into the back then along the paneling that runs under the LH window. From there I just routed it up under the door sills and up to and under the dash. Plug it into the screen and Presto!
***Note*** I had JUST enough wire the way I routed it. If you received the same amount I did, then it's possible.
Like I said, hit me up with any questions. The way it's wired, it will come on and turn off automatically when you put it in reverse and take it back out.
EDIT: That white stuff on the box is silicon. I basically removed all doubt of it being weather proof. And I eventually will clean off a spot on the frame and actually stick the box to it.
dropmech
dropmech
Puddle Pirate
Coral Springs
goood shit homes! how ya like it?
It's awesome during the day. I'm definitely going to have to get some brighter bulbs for night time reversing. It's pretty decent at night if there are street lights around, but if it's pitch black out, then it really doesn't work that well.
AtomicHoe094
Atomichoe094
cleveland, OH
thats cool. i think im going to mod my camera part so it doesnt sit on my license plate. im not a big fan of how "big" it is..
dropmech
dropmech
Puddle Pirate
Coral Springs
Let me know what you end up doing. I'm not a big fan of it myself, but at the end of the day, I only spent $30 on the stinkin thing.
easybake
i can't seem to find this on ebay, do you have a link i could check it out at?
dropmech
dropmech
Puddle Pirate
Coral Springs
Can the reverse wire be spliced to the trailer harness?
That I'm not sure of. I think the only time you have constant power going to the trailer harness is when you have your lights on. Other than that, I believe the wires aren't hot until a ground is provided either thru actuating the brake or a turn signal. Someone correct me if I'm wrong here.
OmarR
Indianapolis, IN
If you guys are talking about the 7 pin harness:
Constant 12V
Ground
Reverse lights
Left turn
Right turn
Parking lights
Trailer brake power
vatahoelt
NoVa
anyone on here good at fixing electronic stuff? got one of these from denaliak and the screen won't work.
dropmech
dropmech
Puddle Pirate
Coral Springs
You first need to find out if power is getting beyond the box, then to the screen. Check point to ground with power applied to the harness. If' you're getting power all the way up to the screen, then it's probably the screen that's messed up. Not sure what you would do at that point.
vatahoelt
NoVa
yeah, there is power getting up to the screen. i was able to diagnose that part. just wish i knew enough about the circuitry to find out why the screen isn't working.
DenaliAK
Colder than you
Alaska
Yeah, I can't figure mine out, either. It worked for like ten minutes. Then it was sort of random and intermittent. Now it just doesn't have anything on the screen. Wish I had another monitor I could hook it to to see if that is indeed the problem.
Dropmech--Do you think that the image from the camera would show on another screen hooked up via the S-video connector? Maybe you could check since you are the only one with a working unit....lol.
If it'll work, I may just find some other monitor as an alternative.
vatahoelt
NoVa
the only s-video plug i found was the one with the power wires connected to it.
DenaliAK
Colder than you
Alaska
Ahh...
There's gotta be a way to wire it to another monitor, though.
dropmech
dropmech
Puddle Pirate
Coral Springs
I don't see why it wouldn't work. I don't have anything available to me though to test it out. If you want to send me your screen, I can hook it up to mine just to make sure your wiring isn't all messed up. Just because you're getting power to the screen doesn't mean it's the right power.
johnsonwillie199
