Change the color of your 00-02 Tahoe/Yukon AC control backlights with LEDs
Tahoewhat
Ballin' on a Budget
TX
Yeah, the digital controls are different. Just slightly different though. The install is very similar. I did digital controls for a member on here, Z-56HOE.
and tahoewhat. lol.
jdixon74
Tennessee
I have a 2002 Tahoe and my HVAC has 3 boards in it. I had to trace everything because what is listed in the OP does not exactly work with the 3 boards. The small board with the original 3mm lights on it does however by resisting the wire for the whole board. The 2ndary board that has the 4 5mm lights on it however i had to resister the last 2 LEDs instead of skipping like in the OP. And be careful on soldering the PCB as you can easily rip off the metal traces while putting in the LED feet. I did but i scratched off the area around and just soldered to it.
S
ScottyBoy
Shreveport, La
You have the Automatic climate controls then. That panel is a bit more involved, but still similar.
Nuuze
Hello Everyone,
I recently bought a used 2002 Tahoe and came across this board. Been lurking reading all the tons of great info here! So here's my first post...
The AC control buttons on the bottom work but the lights don't for the four buttons below. (Fresh/Recirc/AC/Defrost) I was wondering if this is a common bulb problem that can be purchased and resoldered or can it be somethig else? What size bulbs are these and can they be bought at Radio Shack or Frys Electronics? Thanks!
Nuuze
Hello Everyone,
Disregard, they were burnt. I was able to swap them out to LED bulbs after reading the thread. Thanks!
jaykel
Scottyboy i really need ur email addy, im deployed in afghanistan right now and can only get on the internet for about 15mis a day and i have a 03 tahoe z71 with the heated seats and the digital out read for the ac controls and want to do everything all four doors, everything in the dash, i already read where you got the leds and resistors from and ima get the ons for the puddles, glove box, doors and over heads from superbrightleds.com i just need a breakdown on what you think ill need from oznium.com to do the rest, and i kno ill need 10 for the cluster. if you could get back to me at [email protected] it would be great so i didnt waste 10 of those mins trying to get the forum loaded...thanks man
tino ramirez
Minot AFB, ND
scottyboy, i have an '03 tahoe with the LCD screen. i just took a look at the circuit board and it seems pretty easy to do. i just have a couple of questions. would i still put the resistor in the grey wire? also, i'm going to use a 3mm blue led bulb, would i still use the 330 ohm resistor as well?
UGA Tahoe
Jacksonville, Fl
What a sweet look. I would love to get started on my 05 tahoe but I am not very good with electrical components. Maybe another day.
SIK_9D1
Just Finished up the Ac Controls. Was not as bad as thought it was gonna be. Just ordered my Led's to do my instrument Cluster! :)
dadsyukon
What would you charge to do this to my 2006 ac controls? Can you do the stock radio too?
Atreuce
Hartsville, SC
Same here... what would you charge to do my AC lights, headlight switch, fog light switch, rear AC control lights, and the window controls on driver side.. not sure if passenger has it, but if it does, that too. I'm in a 03 tahoe.
Definitely willing to pay to get this done :D
SIK_9D1
I just did all my dash ac control, 4x4 switch, headlight switch, fog light switch, rear window wiper and Cluster. Took me a few hours to do it all but wasnt to bad. Today its raining in beutifull sunny sothern california so im gonna go ahead and do the window switches. I also took the Onstar buttons apart and i think i found some leds that will work in there!
weiserte
Helppp
i know you did this post awhile ago but i want to do all my interior lights i already did cluster just need to do ac control, headlight switch , door pannel switchs how much would you charge to do this if i pay shipping both ways?
S
ScottyBoy
Shreveport, La
Here is what I charge.
AC control panel-$50
Headlight switch-$35
Power mirror switch-$20
Drivers side window/lock switch-$40
Passenger side window/lock switch-$30
livingez_123
Sandy, OR
I think it would be great if someone would offer up a service to change all of the dash lights and all of the other switches in the truck...like the widow and door lock switches. It would be nice to have all of my switches light up again.
NjA4207
