Lift Keys, 2" Spacers, 33s on 20s
FAT SS
Royal Palm Beach, FL
I did new keys in the front of my z71 and cranked them up and used the shock extenders and left stock shocks in. And in the rear I have helper bags that I just keep inflated. Anyone know what part number Bilstein 5100 I should order by anychance? Not to thread jack here.
godoy
utah
If I decide not to sell my truck I'm lifting it just Like 01konvicts truck
I like it a lot
Sent from my TeleFonO!!
Cscottsss
Those Ballistics really look great. First time seeing them on a Tahoe/Yukon.
Great looking truck man.
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
Thanks for the compliments! I did a denali headlight retrofit with morimoto projectors, euro clear corners, new fog lights, and debating getting led tails. I will post some more pics when I get all the lights complete. For the 5100s, they can be ordered for stock length which would require shock extenders or you can order the longer shocks and avoid the extenders. I highly suggest to order the longer shocks and below are the part numbers with year/model info (repost from previous page).
Front - Bilstein 5100 Offroad Shock: F4-BE5-C153-H0 (99-06 0-2" Lifted Chevy Tahoe shock)
Rear - Bilstein 5100 Offroad Shock: F4-BE5-6682-H8 (94-02 0-1" Lifted Dodge Ram 1500 shock)
01YukonXL
Jasper, IN
Z71/denali/escalade top pic vs. LT/LS/SLE/SLT stock
They are taller and have more coils, about 17.5" to 15". They also handle 800lb more payload. Hope this clears up questions about z71 springs.
What years of springs will work or should I be looking for? I may have found some z71 springs that are supposedly for 2007-2011. Didn't know if they were the same or not.
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
You should look for 00-06 Denali/Escalade/Z71 springs as they are all the same which they are known as "z71 springs". I have read from a guy on this site who purchased the 07+ z71 springs and they work perfect. I think he stated he got them from ebay for a deal. Just compare the number of coils in the picture to the ones you are looking into, should be the same coil count.
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
Well I did some updating to my Yukon lights and installed Denali headlights with retrofit Morimoto Mini H1s, euro clear corners, new fogs, and LED tails. These pics show the update and debadged a little more, also took a close up pic of the wheel and tire.
01YukonXL
Jasper, IN
Sweet! Looks great! I should have my new wheels and tires next week! I've got the Bilstien 5100's and leveling kit. Now, just have to find time to do it. My next 4 weekends are tied up with my daughter's travel basketball. May be worthy of taking a vacation day to do it!
2005SnowKon
Fort Collins, CO
What offset do you think I need to get ny tires to stick out alittle. Just did my taxes and getting new rubber. Either 295/70r17 nitto trails or nitto terra grapplers.. not to many choices in that size
Sent from my SPH-L710 using Tapatalk 2
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
For your stock wheels to stick out maybe a 1" wheel spacer. If you want aftermarket then you need to compare the rim width and offset choices. Most of the time you would want a +0mm offset.
2005SnowKon
Fort Collins, CO
What will a 0mm offset do for me?
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
For example if you have a XD series 20x9 wheel and they offer -18mm, +0mm, +18mm. The -18mm will stick out about 1.5", the +0mm will stick out about .6", and +18mm will look just like stock.
2005SnowKon
Fort Collins, CO
So I should figure out what I want first then talk to a place that sells rims
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
Yea if you want new wheels then get some that offer a +0mm offset, if your going to keep your stock wheels then look into a wheel spacer. As far as tires are concerned either Nitto Terra or Trail are great tires. I prefer a all terrain tire over a mud tire unless its a fully lifted truck.
2005SnowKon
Fort Collins, CO
+0mm would br the better choice then? Sticks out alittle but not too much where it lookw funny?
wreedps
Is your Yukon a 2wd?
---------- Post added at 07:50 PM ---------- Previous post was at 07:46 PM ----------
So could I just swap the Z71 springs into my 2wd Tahoe?
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
My Yukon is 4wd and yes you can swap the Z71 springs in your 2wd. If your looking to lift your 2wd just with Z71 springs you will only gain about 1/4" rise. To lift your 2wd drive with Z71 springs you also need a 1.5" lift spacer and 3" lift spindles. Let me know if you need more help.
BlackDenali04
Dud your Yukon looks awsome i want this kinda lift on my 04 yukon denali with 33". Do you think all this stuff would work on a AWD 04 Yukon Denali?
middelgriff1
Maryland
I went with 2" spacers with my stock wheels and loved it. Looked sick and then switched to 0 offset wheels and it brought them back in to 3/4" outside of wheel well
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
You can lift a denali with the same keys and spacers. Some say above 2" lift can cause vibrations on the AWD but there are plenty of trucks running level kits with no issues.
dizhai
