2" Leveling Kit Installation
TXST8tj
I recently installed a Rough Country 2" leveling kit on my wife's 2010 Tahoe.
My wife is used to me modifying every vehicle we own and have ever owned, so why would this be any different?........well this time SHE asked for it to be done. :Big Laugh:
In my spare time, I install a lot of lift kits and accessories; mainly on Jeeps, but on just about any truck and SUV as well. I happen to install a lot of Rough Country products. I install whatever kit and brand my customers want, but so many of them choose RC for their wide range of kits and low prices. I am very familiar with the RC 2" leveling kit for 07+ Tahoes, Suburbans, and Silverados. When it came time to pick a kit, it was an easy enough choice.
I have installed about 13 different brands of leveling kits for our platform and they all accomplish the same thing. The RC kit is the fastest install because it does not require removing the strut assembly. Most of the steps in this write-up applies to the upper mount style of spacer, this one just bolts to the bottom.
Let's get started.
Here is a pile of tools. I use an impact where possible/needed; however, it is not needed. Basic handtools get the job done.
In that pile, you are looking at a floor jack, jack stand, hammer, socket wrench, various metric sockets, various metric wrenches, socket extensions, flathead screw driver, and an allen wrench.
Step 1
Pop off center wheel cover.
Step 2
Break lug nuts loose.
Step 3
Jack up one side of the truck from under the lower control arm.
Step 4
Place jack stand under frame and lower vehicles weight on jack stand. Keep the floor jack under the lower control arm with light pressure for support.
Step 5
Remove lug nuts and remove wheel.
Step 6
Using an 18mm deep socket and several inches of extensions (I use two that equal 15"), loosen but do not remove the upper strut nuts.
*an 18mm wrench can be used from the side of the wheel well if you don't have the ability to come from the top.
Step 7
Using a 15mm socket, remove the lower strut bolts.
Step 8
Using a flathead screwdriver, remove the lower nut clips. (only if installing this style of spacer)
Step 9
Using a 15mm socket from the bottom of the swaybar link and a 15mm wrench from the upper nut, remove the bolt and link.
Step 10
Using a 21mm wrench, remove the tie rod end nut.
Step 11
Using a hammer, knock the tie rod end loose by knocking the spindle.
Step 12
Disconnect the ABS connection at the plug.
Step 13
Remove the ABS line to allow additional slack when lowering the lower control arm in a future step.
Step 14
Using an 18mm wrench, remove the ball joint nut.
Step 15
Using a hammer, knock the upper ball joint loose by knocking the spindle.
Step 16
Lower the floor jack enough to make space to slip the spacer in.
Step 17
Install the new bolts, washers, and nuts through the spacers and struts.
T
TXST8tj
Step 18
Using the floor jack, raise the lower control arm to reconnect the upper ball joint. Just start the nut to hold it together at this time.
Step 19
Using a 17mm socket and 17mm wrench, tighten the bolts and nuts.
Step 20
Using a 10mm wrench on the tip of the tie rod stud to prevent it from spinning and a 21mm wrench on the nut, tighten the nut.
Step 21
Using a 7/32 allen wrench on the underside of the ball joint stud to prevent it from spinning and an 18mm wrench on the nut, tighten the nut.
Step 22
Reinstall the swaybar link using the 15mm socket and wrench.
Step 23
Reconnect the ABS wire.
Step 24
Reinstall the wheel/tire
Step 25
Lower vehicle back to the ground and torque lug nuts.
Step 26
Reinstall the center wheel cap.
Repeat on opposite side.
LTN09
damn wish you were closer, Im not able to do this on my own. Might mess something up.
akbrener
Baltimore, MD
Nice write up, you did alot of extra work though. All I did was pull the sway bar end links, popped the ball joint loose, and lower shock bolts. about 10 mins on each side.
** edit, missed your note about showing stuff for top mount installs as well.
Regency
Nice man, looking into these leveling kits as I'm gauging interest can you post a link to where you got it from?
If you can thanks man
Sorry just saw the post on top.
TacHoe
DC
Dont have a NNBS but have done plenty of write ups for the Audi, wanted to give a kudos as this is very simple to follow! Thanks!
T
TXST8tj
Thanks, and no problem guys. My write-ups typically have much better photography, but I literally decided to do it when I started the passenger side, after finishing the driver's side.
The RC instructions are actually quite good...as they typically are...but sometimes it helps folks to have slightly better/more specific pictures. Of the countless brands of kits I have installed on various vehicles, Rough Country ALWAYS has the best instructions.
ToddEdge
Trophy Club, TX
Great write up!
I just installed a very small(1") leveling kit on my '07 Denali. The good thing about 1" and 1.5" kits(spacer under the strut) is that you don't have to seperate the upper ball joint or tie rod. Just push down on the caliper and you have just enough space to slide the spacer in.
Todd
jrob56
Besides ease of installation, any advantages/disadvantages to this vs the top spacer style? Reliability/longevity etc? Cant think of any really, but curious.
mikebrawn1
Like somebody else said. You don't have to pull the ball joint or tie rod end off. Just pull bottom two bolts on strut and loosen sway bar link or remove if you desire and push down on rotor or caliper and you will have enough room to install the lift. Should only take a few minutes to complete. i just replaced my struts with quick struts and just pulled top nuts of strut, bottom two bolts and loosened sway bar end link. Very easy job. Took 5 minutes each side. Sits higher in the front but will settle down some.
bobbyf1989
Step 18
Step 19
Step 20
Step 21
Step 22
Step 23
Step 24
Step 25
Step 26
Thanks again, nice write up
Wake
Stafford, VA
One thing to add that I didn't see here is that the drive characteristics will change if your vehicle has the active suspension Z55/Z95.
On my Escalade I added the 1.5" spacer and the ride went to crap, very harsh. Going over small dropoffs and the front tires would squeak as they lost contact on the transition from the higher to the lower surfaces. After checking a few items I noticed that the ride control sensor on the front UCAs were extended further than prior to the leveling kit. It makes sense since the suspension is now extended further than stock.
I purchased longer bolts for where the ride control sensor arm bolts to the UCA and a small 1/2" spacer to place underneath it, raising the ride control's sensor arm higher, back to where it was at stock ride height. The ride went back to stock comfort now that the computer didn't see the front suspension over extended. The stock bolts at the sensor are too short to add any spacer under the sensor mount so you'll need new bolts. M6-1.0 x 40 for the bolts and nylon 1/2" spacers and also some lock nuts for the other end, all found at my local Home Depot. About $8 and I had my good ride back.
Before installing one of these leveling kits on an suspension with ride control I suggest taking a picture of the orientation of the ride control sensor arm and measuring what size spacer you'd need to compensate for the further extended suspension. You'll need to duplicate that setting once you get the leveling kit in or you'll lose a lot of ride quality.
Cristian_Zamora
I've got a 2012 Tahoe LTZ that I'll be putting a 2.5" front, 1.5" rear kit on. The ride on this thing is already shit, I mean rough, and I mean rough. But I'm getting into this Tahoe coming out of a Range Rover, so my idea of soft may be slightly unattainable with this Tahoe. Looking at the ride control sensor setup, I don't see where you could add a longer bolt. I can see where removing the original rod and replacing it with a longer piece of threaded rod would work, but a longer bolt? Could you take some pictures of what you did and post them here?
As far as the rear, I was planning on doing the same thing at the rear since I'm also lifting it.
D R Bishop
Mill Spring NC
Hi all I just wanted to share my install of the RC 2" level kit on the front of my 09 Yukon Denali XL. With the help of my son all I did was jack the front up and place on stands. I unbolted the two bolts on the bottom of the strut. I then placed a long bar across the top of the tire into the coil housing and had my son push down. It opened the gap rite up and I slid the spacer in with no problems. Job took 15 mins and that was taking my time to secure it on the jack stands. I only had to removed the two nuts and bolts and replace, Done :favorites37:
TejasPitt
