Installing Locking Lug Nuts
FatBob
Do your self a favor and get rid of the locking nuts. You’ll never find the key when you need it most. I have two sets of black gloss locking nuts if anybody’s interested.
Were they supplied by GM? Do you have the key?
jfoj
At least my 2024 with 22" wheels I had locking lugs as an option. Apparently GM ships them in a small black plastic box about 4"x6"x1" with the vehicle. The dealer PDI department is supposed to install the locking lugs. My dealer put the factory lugs in the locking lug box with the locking lug key and placed it in the glove box. The sales rep made sure to check and point out to me that the non locking lugs and the locking lug key were in the box and in the glove box at time of delivery.
I relocated the locking lug box to the rear underside storage area in the truck and this is where the box will stay until I need to get tires and I will likely swap the non locking lugs on before tire replacement, then swap the locking lugs back once the tires have been replaced.
Badbob
I agree with getting rid of them. I have had very bad luck with them especially with some of my daughters cars over the years
When was the last time you have seen a car up on blocks
Stbentoak
Yes, two sets gm oem high gloss black with key. Each set, 4 locking lugs.
The price that GM wants for these nuts is absolutely absurd. My up fitter replaced my chrome ones with high quality aftermarket ones I had for about a fifth of the price. They look awesome.
Kpwweb
Badbob
I think when you find your car up on blocks it’s time to move to a better location
dntnvme
I just went through a situation with my 2025 Tahoe RST. I had no idea there were wheel lock nuts on my vehicle until the first oil change/tire rotation. Dealer called me and asked for my key as there was none in the vehicle and they had no master keys. I was never given a wheel lock key or told about the wheel lock when I picked up my ordered vehicle. Appears, at least on the Tahoe, that it is OEM for the 22/24 inch wheels and not listed on the spec sheet. Dealer nor any dealer near had master keys. The dealer recommended to torque/break off the wheel locks and put new ones on. I thought that was a stupid answer and did my own research. I found that Farad, the company that makes the wheel locks for GM will sell you a replacement key if you take a good close-up photograph of the wheel lock and email it to them. I sent them an email and a photograph of my wheel lock. The next day they had a replacement key in the mail. They were a wonderful company to work with, very professional. They can be reached at
In my communication with Farad, they stressed that forcibly removing the wheel lock can cause significant damage to the wheel, hub, or locking mechanism.
When I found out about Farad, I asked three dealers about getting a replacement key and they all said that it was impossible and that there is no correlation between the wheel lock and the vehicle VIN. None of them knew anything about being able to get a replacement key from the company that provides them to GM through a simple email and photograph.
At first I didn't have great concern bout not having the wheel lock key until I realized that if I have a flat tire, the only option would be to have the vehicle flat-bed towed to a GM dealer, if there was one near and if one was open. And then a dealer who probably did not have a master key. A late night, out of town flat tire could have been a real problem, as tow companies do not have master keys for the wheel locks.
Purchase and postage cost me about $30 from Farad. Yes, the dealer assumed responsibility and paid all costs.
I think Farad has been the supplier for GM wheel locks for a couple of years. Prior to that the wheel locks were made by McGard. McGard has the same email/photo type replacement procedure. If Farad did not make your wheel locks, contact McGard. 바쁜 하루를 보낸 후에는 편안하게 휴식을 취하는 것이 중요합니다. 집이나 숙소에서 편하게 이용할 수 있는 서울출장안마 서비스를 찾는 분들도 많습니다. 예약하기 전에는 이용 후기와 서비스 내용, 가격을 꼼꼼히 확인하는 것이 좋습니다. 또한 예약 가능 시간과 제공되는 서비스 범위를 미리 문의하면 더욱 편리합니다. 믿을 수 있는 업체를 선택해 편안하고 만족스러운 시간을 보내세요.
I’d replace them one at a time with the truck on the ground, provided the wheel is fully seated and you’re not disturbing the other lug nuts. Thread each locking nut by hand, then tighten it to the manufacturer’s specified torque using a torque wrench. If you prefer to follow the full torque procedure, do it with the wheel safely supported and follow the proper tightening sequence. Dealers and tire shops commonly install locking nuts alongside the regular lug nuts, but practices vary. Keep the key somewhere accessible, and recheck torque according to your owner’s manual.
alexblagoev
