Autoride bypass
fiatdale
Houstons Best
Houston
I've done a lot of searching and cannot come up with a straight answer. Can the 25 watt 3.9 ohm resistors work on the 2007+ SUVs? Can anyone confirm or deny this?
fiatdale
fiatdale
Houstons Best
Houston
I'm surprised nobody has responded to this. I'll be getting the resistors in today and will post shortly on if this will work for the 07+.
red02chevy
Lubbock
Cool post your results. I just picked up another tahoe and will be lowering it soon and don't want to deal with the dash lights.
Jimmyp19
NH
I'd like to finally know this as well, stupid service suspension message for over a year
NORCAL SS
SUV SUSPENSION GURU
i just got the resistors online on ebay. I havent had a chance to pull them out of stoarge to ohm them ill try this weekend.
fiatdale
fiatdale
Houstons Best
Houston
May want to sticky this:
25 Watt, 3.9 Ohm resistors work perfectly for bypassing Autoride on 2007+ SUV's. I chopped off the connector and soldered the resistor across the two wires, then heatshrunk. Doesnt matter what side attaches to what. No error messages.
Now you can put any shocks on without "Service Suspension" messages, and youre only out about $10.
You can purchase them here
Jimmyp19
NH
Will these work for the rear as well?
rocketman76
Fort Knox, Kentucky
You are the man, I will definately return Arnott their shocks.
Now comes the task of figuring out what shocks to get.
QA1s are awesome pieces, I just need a part number for front and backs.
fiatdale
fiatdale
Houstons Best
Houston
Arnott shocks do come with resistors, but they will not sell them separately from the shocks, so in order to get their resistors, you have to buy their shocks.
Buying the resistors I posted costs less than $10, and you can add any shock you like. I added just regular gm factory shocks (non-air) which can be had very cheap and still give a great ride.
wht06shee
So is there going to be a how to or DIY on this bc I will need to do this once I get my drop kit on.
fiatdale
fiatdale
Houstons Best
Houston
There really isn't much to say about it. A resistor has two sides (one wire coming out of each end). Solder or butt connect each of those wires to the two wires that are on the plugs for the air ride shocks (clip the connector off). Heat shrink and / or use electrical tape to cover the joints, then zip tie it out of the way.
It's extremely easy and you really can't mess it up.
wht06shee
Well that a lot easier than I was thinking, ill just need 2 resistors??
fiatdale
fiatdale
Houstons Best
Houston
One resistor per shock. Replace the rears - need two resistors. Replace all 4 - need four resistors. I purchased 8 just to have some spares, should the elements eat them up over time. Ive been running them for over 2 months now with no issues, and no "service suspension" messages. Cheapest fix ever.
wht06shee
Did you buy helper bags to make up for not having auto ride??
fiatdale
fiatdale
Houstons Best
Houston
I don't tow anything with mine so I don't feel the need. I'm also not lowered.. Yet. I just wanted to be able to install cheaper shocks than the autoride ones. Even the arnotts are a big chunk of change. I got a great deal on some factory shocks that were non air ride and put those on. Still rides the same as the autoride shocks.
Charlie21ny
