Interior LED How to
_Dylan_
STAY FROSTY
And dylan if you mount that monitor where your radio is where are you putting the radio,i have been sceaming on this idea for awhile myself just not sure how i want to set it up
Sent from my Galaxy Nexus using Xparent Blue Tapatalk
I'm going to try to put it on top of the dash in the far left corner. I haven't tested to see if it would fit though.
juggjiggler69
I just ordered 3mm led red ones so i can solder them in
the big blue bus
richmond, va
when i get my leds in ill post how i did the led door switchs.
for the map lights i got some bright ones off ebay and had to pop the lense off shaved some of it down and stick em in then superglue the lese back. there are weird spots from the glue now on the backside of lense but oh well
juggjiggler69
I just let my lenses off my map lights looks good also
the big blue bus
richmond, va
im talking about the round ones in the roof console and the rear dome light. i have my front dome light cover off too because i hate the white cover it has and i need to find some brighter ones for there
95yukonslt
where are you buying the leds for the door switches? I would like to know the 'model' nummber. Thanks, nice hoe btw
juggjiggler69
I ordered some from superbrightleds.com but they do no light the switches up so i mite just say the hell with it and solder some in,the problem is the light shines straight not 360°,i soldered one in for the window switches that works good but the window lock and door lock dont light up at all so i got to figure something out
juggjiggler69
Oh and as far as the 4x4 switch just order some #74 red led off ebay and take them out of the housing and solder them in they already have the resistor on them
the big blue bus
richmond, va
i had em from sbl. they were the neo 3 and 4s. forget which but the drivers one for the windows i believe needs to be the high power one. the standard one is too long. ive since done one 5mm led under each switch on the passenger side switches to practice with cheap leds from radio shack. when my blue come in all finish the rest of them. i did have blue in the passenger switch and it was blue, just not as bright as even of light as id like. maybe the high power ones in all of them wuld work better. i have the led in headlight switch too and its dim. going to led retro 4 or 5 in that as well...
KPOD
Michigan
Just ordered a set of these to go in my dash. I was gonna go with SMD 5 LED bulbs, but at $6 a pop I decided I would try these other ones first since they are similar and only a fraction the cost. Will report back with pictures my findings after getting them installed this weekend.
Chris2388
I Know it old but does anyone have a pic of the green or blue LEDs in there dash?
miskis
Courtice, ON, Canada
Hey Guys, I am going to order a set of 6 194 blue's for my dash.
http://www.superbrightleds.com/more...194-led-bulb-5-led-wide-angle-wedge-base/199/
I also want to order a set for HVAC controls and all the other buttons on my dash. I have a '97 SLT with 4x4, does anyone know the other type of bulbs I will need to complete this swap? I want to order all of them at once, so I only pay one shipping. Especially since I will be shipping to Canada.
Thanks
P.S. I will also post up before and after pics if people would like to see for comparision.
ColoradoTahoe
Colorado Springs
Check it out
My stupid phone just won't post this damn pic the right side up. Haha
ColoradoTahoe
Colorado Springs
Thanks
I went to modifiedlife.com to get all the info I needed. At the top of the page there is a link for all the lights you need for a swap. Just search your make and model :)
bamaboy73
what about the interior dome lights? anybody do thoes?? what bulb?
1BADI5
DMV
Great thread, I upgraded my cluster and HVAC controls yesterady
Conedaddy
