Just installed Tony's 6" drop springs
My07hoe
I just installed Tony's (NorCal SS) 6" drop springs the other day on my 07 tahoe and it looks bad ass!! For some reason I can't upload any pics from my phone. Ill upload some when I can get to my laptop but tony posted a pic on another thread in this forum http://www.tahoeyukonforum.com/forum/showthread.php?t=48097 . I'm sittin at 32.25" from ground to fender lip at the rear and 32" at the front and I must say that the ride is GREAT for being so low. In the front I used belltech 1" drop springs, and belltech 2" drop spindles. I did the free travel mod where you cut off the bump stop brackets and install smaller bump stops and im using belltech shocks and 6" drop springs in the rear. I also Installed his front and rear djm sway bar package, rear endlink kit, trailing arm brackets. Im currently on 305/40/22 tires. I ordered the airlift 1000 part #60742 last night for the rear and I should be gettin them tomorrow. Ill install the bags this weekend and let you guys know how it turned out.
KMeloney
Wow! It's sitting down like a Volvo wagon! Crazy.
NORCAL SS
SUV SUSPENSION GURU
im at a tad under 34 and I have a 2.75 drop (spindles and 3/4 from my strut mod) on 305 35 24 and your truck is a lot lower than 1/4 inch more than mine lol.
Thanks again pete hit me up when you get the helpers in.
The kit ill be setting up will use struts and spindles but pretty much look like yours.
Modded
That Guy
So your saying the front fender is 1/2" and 3/4: off the front/rear tires respectively?
Ok. Looks good! :D
Do you have more level pics?
NORCAL SS
SUV SUSPENSION GURU
Just got 50 sets today!!!! 6" rear drop spring in stock ready to ship
My07hoe
My07hoe
I put them in last weekend and it rides nice. I'm still chasing a small air leak and I will be pulling the boat out his weekend. Ill post some pics up this weekend
NORCAL SS
SUV SUSPENSION GURU
pete read post wrong you can forget about pm lol.
shoot me a pic of the bag in the spring with weight on it
My07hoe
My07hoe
I finally got time this weekend to take some pics of the helper bags. I used the airlift 1000 part #60742. I installed the psi gauge next to my headlight switch since I had an empty compartment that was useless. I also mounted the switches next to the steering wheel where they won't be an eyesore. I mounted the compressor above the spare tire
NORCAL SS
SUV SUSPENSION GURU
Looks good. Im glad i went with a non progressive design. This way you can see the bag acatually fits in between all the windings. Thanks again man. Now load her up lol
veteran111
