Tahoe pics with cooper zeon's
pavich91
Vancouver BC Canada
Hi guys,
Decided to get the Cooper Zeon's but not sure if i should go with stock size (275/55/20) or something else. Pics would be great if anyone has this set up.
Gael
Laredo, Tx
dont get 275/55r20. i was running those and they look crappy. i'd go with the 33x12.50x20
pavich91
pavich91
Vancouver BC Canada
Ya,i have stock size on there right now, your right, looks crappy.lol
Def going with the 305/50/20, just worried about rubbing
2000Yukon
Nebraska
The only time you might rub a bit is at full lock and flexing the suspension a bit.
Had Zenon's in that size and only had minimal rubbing.
pavich91
pavich91
Vancouver BC Canada
So if i drove on some rough terrain, would it be rubbing like crazy?
Not that i take this through the bush or anything but i drive to some wild construction sites once in awhile.
hoe
I bought the cooper zeons today for $1000 shipped
Hope they work out good
didnt see this thread earlier... but I run the 305/50/20s, with wheel spacers... cause Im a bad ass... and yet still I have 0 rubbing unless I try to do something crazy, besides all of that, Im lowered 2/4 on top of that...
pavich91
pavich91
Vancouver BC Canada
Lol, good to hear. Then i shouldn't have a problem, or even need spacers if your lowered and don't have issue.
What size spacers are you runnin? Tires stick out past the fender?
jmyler
atlanta
Don't know if it helps but i have 305/45/22 cooper zeon's which should amount to about the same height, with zero rubbing. From the picture it looks like the back might stick out but if you look over the top of the tire it's almost exactly in line with the back fender.
imi4tth3w
i had them in a 305 55 20 (33 12.50 20) for a while before i went bigger on my truck and sold them. didn't really have them long enough to really test them out. basically a slightly cheaper nitto terra grappler. keep them rotated every 5k and at proper air pressure (35-40psi depending on what load range they are). not going to last as long as nittos would but still a good tire.
01Konvict
Boats n Hoes
Raleigh/SML
The tires look great, you can always crank your keys up a little bit if its not level right now.
Drewphil
