AutoZone Magnaride Front Struts
Spencer2705
Has anyone just replaced their front Magnaride struts with a AutoZone replacement? I did this and they were a exact match. My old struts had almost locked up and were giving a terrible ride. The new ones ride great but now my suspension light has come on twice. Just wondering if anyone else has had trouble with AutoZone struts?
2019 Tahoe Premier 5.3
Spencer
It appears that Autozone is using Arnott struts for Magneride replacements, which I believe are rebuilt GM OEM struts. Arnott had a good reputation for years, but I have 'heard' that their reputation for product quality has taken a hit in recent years.
First check to ensure that the electrical connections on the tops of the struts are clean and tight, as any motion that would temporarily open that circuit would trigger a trouble code and dash light.
If the electrical connections are clean and tight, then you will need a quality bi-directional scanner to dig deeper to determine the source of the trouble code.
Spencer
I would double check your work and be sure the harness connector on the top of the strut is properly attached, if it is loose or not connected properly it can loose connection while driving and throw a code, then clear it's self when it has a connection again.
this would explain a intermittent suspension error
Lundgren
Spencer
Did you get this sorted? I need to do mine.
Sundancer
Army Law Enforcement
Long Island, NY
i need to replace my front shocks that are magneride RPO Code Z95 but not even sure what to get at this time
Fless
Moderator
People's Republic of Colorado
Suggest adding your vehicle info to your signature so we know what you're working on. Year, make, model, engine, etc.
Tag @915_Tahoe (like I did here) with the last 8 characters of your VIN and ask him for the GM part numbers.
lukeweigler
I recently did front struts and springs on our Yukon. Our mechanic friend begged us to not go the cheaper/easier route of aftermarket assemblies. He said, if they're magneride replacements, they should ride nice but he's ALWAYS had issues with them throwing codes. He said, save yourself the headache and go OEM. So, we went the OEM route and I couldn't be more thankful that we did. I ended up with a 2nd set of front struts and springs (long story)!
Lundgren
I replaced mine all around using parts from rockauto. I got the GM GENUINE 84176675 for the rear with the lifetime warranty and the strut and shock assembly for the front: ARNOTT MR5358 (MR-5358).
The rock parts were so much cheaper that I could not justify supporting my local brick and mortar parts place.
I initially ordered the 2wd version for the front and had to return them to get the right 4wd version.
I watched several how-to videos online to get the overall process and what to look for down and then my son and I did the swap. I needed tires as well so I had them replaced and bought a lifetime alignment at the local firestone.
The ride is restored and I am happy with the result. I have put around 200 miles on them is all so far. I have no complaints.
Bob Lob Law
The rock parts were so much cheaper that I could not justify supporting my local brink and mortar parts place.
What did that run you if you don't mind me asking? I'm going to be doing mine soon enough.
Lundgren
Too much. Around 2 grand for all four parts. Much cheaper than anywhere else I found but still more than throwing out the mag suspension. I am planning on keeping it for a long time though, so I did it.
Now I know that all four of mine were frozen. It did not ride well.
Bob Lob Law
I'm gonna spend the money and put magride back on when mine need replacing. I really like the way it rides!
Charli1964
