Question about 1-2ohm subs...
knoslf
Thornton, CO
Okay guys heres where I'm kinda confused....plan on getting 2 AQ hdc 15" subs(1200w rms a piece) and they only come in 1ohm dvc or 2ohm dvc and I intend to run a Hifonics BRZ2400.1d for both or the BRZ1700.1d for each sub, both mono amps to be ran at 1ohm. I know some of you may be against Hifonics but I love their amps and have never had any issues with them and they are affordable and are 2006 cea compliant too. So...if I go with 2 1700w amps(1 per sub) should I get the 1 or 2ohm dvc subs and if I go with the 2400w amp to power both would I need the 1 or 2ohm subs?
http://www.amazon.com/Hifonics-Brutus-BRZ1700-1D-D-Class-Block/dp/B0036B8URU
http://www.amazon.com/Hifonics-Brutus-BRZ2400-1D-D-Class-Block/dp/B0036B8USE/ref=sr_1_1?s=electronics&ie=UTF8&qid=1347232514&sr=1-1&keywords=hifonics+brutus+brz2400.1d
http://www.audioque.com/HDC315-Copper-Coil-Subwoofer_p_24.html
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if 1700w is chose the buy the dvc 2 ohm per coil and wire coils in series to have the amp see 1 ohm load. for each separate amp/woof combo. if you choose 2400w amp 1 ohm dvc you want to wire it as such.
K
knoslf
Thornton, CO
Thanks for chiming in SunlitComet! Yea I most likely will go with (2) Hifonics BRZ1700.1D amps, one for each sub, so you're saying I need to get the dvc 2ohm subs to draw a 1ohm load from the amps?
K
knoslf
Thornton, CO
yep. it will wire like this.
Thanks, im gonna get the dual 1ohm subs and the 2 amps, big 3 upgrade, and will prolly need to do the ** Alt and dual batts idk...** alt are sooooo expensive man...there's a place here in Denver that'll rebuild your stock for a higher output but it depends on how big the alt is i think. Plus I intend to ryn a smaller 2ch amp for the 2 pairs of door 6.5's, like to hear hard hitting bass but also love some nice clear crisp highs too.
_Dylan_
STAY FROSTY
I would get the 2400. Save $100 and it's not overpowering the subs.
K
knoslf
Thornton, CO
if dvc 1ohom each on each of subs your wiring options will be either 0.5 or 2.0 ohms as seen by the amp.
Then if I do the 2 amps/2 subs(each sub has its own amp), i have to get the dual 2ohm subs?
---------- Post added at 12:41 AM ---------- Previous post was at 12:39 AM ----------
Yea I know, but I've read so many reviews saying these subs are underrated and people running 2 AQ2200.1d amps to 2 of these subs so I figured 1700w a piece wouldn't be too bad lol...I just may call AQ and see what they say...
dcil
I'd go with 2 amps. Paralell wiring has less box rise, therefore more power. Also, there is no "too much power" for those subs. Keep them sounding clean, don't over-drive them.
qukon 95
i hope your charging system and batt can handle that 1 ohm load.
i would do the 2 ohm dvc wire them for 4 ohms on each amp.
CKendrick
