Body lift steering extension
slipping
Rosamond, CA
I believe this is correct part of forum...
4dr 2wd. Currently dropped 4/6. Removing finals of my 3" bl and this is the steering extension correct?
If so I cannot for the life of me line the two holes for the steering shaft and intermediate shaft.
Should I leave it?
Any hints tips laughs jokes will be appricitted
Gzes
the drifting 2dr
Wichita tx
I believe you pull it and then put the pin in there. The shaft can be pulled if same as with rams
slipping
slipping
Rosamond, CA
are you sure it had an extension on there?
I am not sure at all if that in 1st pic is the extension or not. BL came on truck so I downloaded an install guide and was going through that a pics off what I could find.
I've been pulling both shafts. Fwd and aft. Went under dash to see if I could push out.
slipping
slipping
Rosamond, CA
BAM! Got that handled! I just wasn't giving it enough ass. I pulled on the fwd one and when it finally unstuck and gave moved like a champ. Lil loctite and back in business. Whooo! Thanks guys!
rossida
