Scorpion 1.6 Roller Rockers Installed !
gpracer1
Phoenix
Well I got the rockers in.....pain in the ***.
The bad part of install is the entire ac compressor and power steering bracket as well as the alternator have to be loosened and moved a bit in order to get the cover over the now taller rockers. Also no instructions of any kind, like I needed them.:sleepy10:
The way the locks work almost caused me a disaster as one came real loose at 5 k rpm and chewed up the valve tip a little, forgot to take a pic :emotions122: Not sure if it was my fault since that one was the sticky lifter I had that finally cleared. Any how I tore all down again and re-tightened, after setting zero lash with the engine running this time to ensure the lifters were actually pumped up. Seems to be ok now.......like will tell.
Pic of having to move bracket.
[/IMG]
Rest of them showing clearance.....I did NOT enlarge the holes in the head.
[/IMG]
[/IMG]
[/IMG]
Notice where the can of seafoam had dissolved lots of crap as I was trying to free a stuck lifter.
[/IMG]
[/IMG]
Good part is it pulls hard at 3500 all the way to 5300 shift point and never falls off like before.
I think the stock rockers were my bottleneck for all my other mods, because I swear with the cumulative mods it made a ~30 hp peak power difference.
Can't wait to dyno it and see the real numbers.
992dr
Eastern N.C.
Nice, I agree. Too bad they have to be covered up.
Did you make any dyno runs before you did this?
It would be nice to see a before and after.
Phone Man
Long Island NY
Any issues with pushrod clearance on the 1.6 ratio? Maybe you have dis-proven the myth about that!
Phone Man
Long Island NY
Read here and on other boards, and even posted q uestions about 1.6 ratio not working with vortec heads b/c of the pushrods rubbing against the head. The conclusion was that the holes had to be elongated, So I went with 1.5's on mine.
gpracer1
gpracer1
Phoenix
I did not have to clearance the holes.
It was close, I took pics so you guys could see....hopefully the pics are good enough.
I did a dyno run last year, I will dyno it again as soon as I can.
I checked my logged runs from 7/20/2011 and the most g/s of air my MAF would flow was 186........now it's 221. !!! So I know its flowing more air. :)
SunlitComet
OBS Jedi-Do Good
unknown at this time.
yep also with 1.6 full rollers you are likely to encounter stud pulling and possibly some knock retard as they get loose.
retorq
Kingman AZ
It's not a myth, its a valid concern. There are alot of parts and upgrades that people do without realizing they need other supporting mods or mods to other stuff they may not even realize. They see something cool in a magazine, buy it and slap it on then later they are here asking why their junk isn't running right.
:lol2:
gpracer1
gpracer1
Phoenix
that looks great man cant wait to see the dyno numbers
Since jan I have been traveling for work 97% of the time, haven't even put my headers on yet.......hopefully soon , then dyno once it cools down from the 100's+
barney91
mesa,az
thanks for the part number, and i know what you mean about the weather ive been needing to replace my oil pump but the crazy rain didnt let me all week intill today
j_jerry79
