Modded
That Guy
- Joined
- May 3, 2009
- Posts
- 6,942
- Reaction score
- 109
I think I have a way you can test the offset w/o looking for the stamp on the rear of the wheel and w/o waiting to take it to a shop.
1. Find a straight stick/rod around the house that is as long (or a bit longer) than your wheel and tire setup.
2. Then get some measuring tape (or a piece of string/wire you can measure afterwards).
3. Starting with the drivers side, line the rod up with rim/tire surface and measure the distance from the back of the brake rotor (part of the rotor closest to the engine bay) to the rod/stick that is against the outer part of the rim/tire. Make sure you are accurate.
4. Now measure the passenger side that sticks out (the exact same way) and check for consistency with the drivers side that is not sticking out.
If they measure the same from back of rotor to outside of the rim lip/tire shoulder, the issues is from your Suburban.
If they do not measure the same, the issue is from the wheel offset.
