Installed - Airlift Helper Bags
NathanJax
Vacation Nathan
Jax, Fl
Finished up in about an hour. Also swapped out my Belltech 5323 3" drop springs for Belltech 140-002 (Trailblazer) 5" drop springs.
Here's the helper bags I used. Air Lift Rear Air Spring Helper Bag Kit #60769
These can be used with any of the drop springs you get.
Here they are installed in the 5" drop springs. Even though they aren't perfectly round, they are fine. Once air goes inside them, they just about even out. A little hard getting them in, but they fit.
Spring installed...
And I ran the lines separately instead of T'ing them together. The kit gives you the option to do either. There are a couple reasons you separate them. One is you can easily get rid of the "chevy lean" were all gm SUVs lean to the driver side. It's because the gas tank is only on the drivers side. Another reason is when you turn a corner, the air doesn't move from one side to the other. It actually helps the suspension almost like a sway bar would.
I drilled holes in the rear bumper by the trailer hitch. I have a hitch closeout so it can't be seen normally.
and then with my hitch closeout on...
Very cool!!! :) anxious to see pics :)
btuckz71
Looks great, how much psi do u run ,and do u tow a lot or do they help with ride and or height?
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
less than 5psi. I'll just fill them up until it starts to raise the truck a hair, then release a little air. It's really there so it doesn't bottom out, to help the sway from side to side, and make sure each side is the same height.
I don't tow much (ever), but when you do, it's easy to fill them up and level the truck back out.
btuckz71
Nice, I need to find a hitch cover but I have a z71 and it looks diff than most or the ones I see don't look like they'd work , any advice ?
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
post pic
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
Yuko04
"SquareBODluvr"
MN
Spring installed...
Looks good! after months of contimplating. I swapped out my BT SP's and put my Sensatrac air shocks back in and use them since I already had them. I do a lot of towing.
NORCAL SS
SUV SUSPENSION GURU
Spring installed...
i put this info up almost 2 years ago on my vendor page here also listed the djm tb springs ones.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
NathanJax - What lowering parts do you have on the front?
Belltech 2" Drop Spindles #2509
Belltech Adjustable Front Drop Struts
waynesoffroad
Clovis, Ca
They look long for that spring. I need a set for when I'm towing my boat. I called Tony for a set but he doesn't sell them. He was suppose to get back to me for the part number and never did. It's been a week!
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
These 5" drop springs are a little short, but they work fine. They were a perfect fit for my 5305 springs.
part number for the airbags?
NORCAL SS
SUV SUSPENSION GURU
check spam mail i sent you the correct part number a while ago.
Freddie
Awesome I have for sale that are new in the box never installed...just got to get to 80 posts so I can post them.
NORCAL SS
SUV SUSPENSION GURU
The 5305 springs need a different part number pm me ill shoot it to you guys. the ones for the belltech springs are narrower you need the wider one to give it more support for the 5305 springs.
X-ray Nerd
