Installing your LED Tails
LordGeek
Ohio
IPCW .. who are they .. do they have a site I can check out ?
tast101
tast101
Colton, CA
http://www.inprocarwear.com/
They have some LED rear vent for you NNBS guys.
Robert.K
San Diego, Ca
Has anybody installed led bulbs like you can do on the interior in there brake lights? the set i have now I love, but would love to have a led look from them.
Tahoe03mm
Puyallup, WA
i never noticed my cruise control stop working until the other day, yet again i rarely use it.. I like to feel in control lol I did install some LED taillights though i'll have to look into installing load equalizers in-line
quick question... what am I looking for in a load resistor and where do I wire it in?
vatahoelt
NoVa
thanks for this thread. got my new tails from Chistos and installed them this morning. Took me about 15 mins.
I did have the fast blinker on the right one, but i switched the plug and it went back to normal.
robb.
dallas
4 months ago i purchased a set of the SONAR LED lights.....Clear/with black housing....and tinted dark
these lights are pretty much the same as the majority of you have.
just 2 wks ago some 1 backed into my HOE at a parkinglot....and well they broke the Plastic covering....
I always wondered about the rectangular red piece on the housing....y it didnt light up.........turns out its nothing but empty space.......but yet there's enough space to maybe put in a small light..
question is....which light should be put there..and where would it be wired from?
it can be used as an extra brake light or turn signal..
robb.
dallas
doesnt reflect much of anything ....especially if the lights are smoked.......so lets put it into some good use
ayeplussjr
Sacramento, CA
These issues that people are having when installing the LED tails (brake light not working, cruise control not working, etc). Are these happening with the LED tails purchased off of ebay or are they happening with the more expensive LED tails from IPCW, Anzo or Recon as well?
justin146
There were some questions about LEDs with barn doors. These fit mine with a little shimming of the screws with washers because the doors rubbed a little. The only problem with them is that I lost cruise. I bought a $10 resistor kit from Autozone to fix it though.
boardrider05150
resistors built in
Hi, awesome tailights. can you tell me what brands have the built in resistors in the led tails? Thanks,
BlacknBlue03
Maryland
I have an 03 tahoe and recently installed the smoked led taillights. The issue i have is my running lights don't come on but my brake and signal lights work fine. I have all the other parking lights and interior lights. I have checked all the fuses related too the parking lamps with no success. Does anyone know how to fix this. I also have an issue with the directionals flashing quickly. I know that is because the LEDs pull less voltage than the regular light but i would really like to fix that as well.
polobuds
East Bay, CA
i have an 03 tahoe as well and have the smoked LED Tails from X3 racing on ebay. they have the built in resistors, and i have had no problems with anything since i've installed it two months ago. With the ones I have (plug n play) you have to make sure the wires are connected properly (ie black with black). If you reverse it, you will get your turn signals flashing quickly. Just reverse them and everything should work fine
mando2776
Van Nuys, CA
How to install your LED Tails.
We had a nice little thread on TF, and I figured I'd make a new one since the tails don't come with any instructions.
For this model, they have a clear version and a red version. Both come normal or smoked.
When you install your taillights, I would suggest numbering you light sockets and writing the corresponding # on the housing, just incase you need to install your old tail and to make things easier.
There are two metal clips that the screws catch on. These are located on your old taillights. You will pull these off, takes a little muscle and prying. But be careful, so you don’t break the plastic on your taillights.
When you hook up the harness' you want to follow the order above.
The Running lights/Brake light will be at the top.
The Blink will be in the middle.
The reverse light will be at the bottom and you will use the bulb for this.
If your lights aren't working check your fuses under the hood. I had a problem with my brake light switch, and it needed to be replaced.
(Don't remember his name off the top of my head, but on TF.com he had a little wiring diagram to have both the blinker and brake light to work in unison like the esky lights) Hopefully he'll join up and chime in.
Here's some pics of the non smoked version:
They can be purchased on ebay:
http://shop.ebay.com/items/_W0QQ_nkwZ2006Q20yukonQ20ledQ20taillightsQQ_armrsZ1QQ_fromZR40QQ_mdoZ
Found a vid:
[yt]zJ0grZP6zAg[/yt]
Feel free to add on other LED brands/models and if I forgot something add it.
question.....
i bought the same led tail lights u have for an 04 tahoe.
once i installed them.... my turn signals were flashing rapidly. and my parking lights werent turning on, just the brake lights... any suggestions? thanks.
btw, i didnt follow your diagram above... i actually used the urn signal on the top and brake in the middle... could this be the prob? thanks....
bkboatnsleds
McHenry, IL
Could be the problem - also make sure the black wires at the plugs line up. I have same ligfhts w/ no issues.
mando2776
Van Nuys, CA
thanks bkboatnsleds... problem fixed..... i did line up the blk wires...
didn't wanna blow the fuses. i did use the diagram above and connected the turn signals to the middle plug. looks great and works perfect...
bkboatnsleds
McHenry, IL
Might have to fool with figuring this out.. I like that look.
ZaZaZazzels
