I want to smoke tires W/24'S
Travieso
Boooooooost !
Los Skandeles, CA
Hey guys After a few days of reading the forums i would like to introduce myself, and not just linger around here, lol
Basically what i want to do is try to smoke some tires on my 24's is that possible ?
So What do i need to achieve this ?
Basically i want to get the best bang for my buck
this is what i currently have (not much but a good start i suppose)
Magnaflow Catback exhaust system
3.75 Gear ratio stock from the dealership
Things that i might buy in the future,
1.Cold Air Intake (can anyone recommend me some)?
I was thinking a AEM CAI - i heard threw the dealership that getting a wet CAI will damage your sensors etc.
2. Long tube headers (can anyone recommend me some)?
3. Chip was thinking of a Superchips Cortex™ Programmer
Will this help me out alot considerably ?
Thanks... Oh i found a new home :)
Here is a picture
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
AEM brute force. Not sure on Headers. But SKIP THE CHIP. Just get a BB custom tune, AFTER all your bolt on mods. Biggest power increase before forced induction though would be a Cam.
tast101
Colton, CA
Welcome to the forum. Do everything JK, Chistoso, and Jennabear have done. hahah Then you be running Ricers with the 24z. Soe engine work and a supacharger!!
blueflamed03
Oklahoma
welcome :cheers: Nice looking ride!
3.73's are nice, but 4.10's would help.
LPP headers, and a Black Bear tune.
AEM or choice of brand CAI.
JKmotorsports
Austin, TX
I can roast my 24s along with a few performance cars:)
If you have the pcm retuned and remove the Torque Management, that will help a lot. Install longtube headers, intake, exhaust, higher stall converter and retune the pcm and you'll be able to smoke the tires a little easier. Cam and heads will make a huge difference and a power adder like n2o or a blower will definitely help you light the tires. And check your rpo codes to see what rearend gears you have. Deeper gears will definitely help.
BTW, welcome to the site:cheers:
Rollin Thunder
Va Beach Va
Just a word of warning here. Your stock tranny cant handle much more power than stock.
JennaBear
Resident Ninja
San Diego, CA
It actually can, you just have to dial the line pressures in right to make it have a longer life.
Cobra
Austin, Tx. area
not 24" but this guy was spinning those 20" pretty good with this..
2nd fastest NA 5.3L, cam only
Owner: Lance - LS1Truck "Bluecajun"
Vehicle: ’03 Chevy Silverado
Engine: 5.3
Mods: Nelson mail order tune, ls1 fans w/ nelson harness, cai, tr220/112, 918's, manley pushrods, pacesetter lt's, custom 3" exaust w/ Y and aerochamber, built 60E, tci 3000 stall, eaton differential w/ 4.10's.
show: 2" hotchkis drop coils, 4" beltech shackles and hangers drop. 20" centerline stingray III's w/ falken 275/45/20's.
track times:
60' - 1.74
330' - 5.08
1/8 - [email protected]
1000' - 10.42
1/4 - [email protected]
Modded
That Guy
Don't large gear skill the gas mileage?
Also I was looking in to TM and read BBTune take most of it out, what about all of it Jenna?
JennaBear
Resident Ninja
San Diego, CA
Torque Management is more than just one thing (comes from multiple functions in the engine), so theoretically you can't get rid of 100%.
Nickleahy23
Portage/Menomonie, WI
you and me both lol..i cant spin my 24s with the 5.3 with BB tune, cAI, exhaust and 3.73 gears.. so i bought a 6.0..thats going in the tahoe in two weeks..i will let you know what that does for spinning the tires lol
JennaBear
Resident Ninja
San Diego, CA
You guys need to remember the amount of weight that is going over the rear axle on these things. It is much easier to do in a truck as the bed is so light over those back tires. It is even worse with the 4X4s, due to the fact, that even when you are in 2WD there is still a small amount of power going to the differential, so you are never really in 2WD.
Nickleahy23
exactly..especially after you add in 250 lbs of stereo equipment and passangers since their weight is also over the axle..go throw 800 lbs in the rear of your bed and see how easily it spins them lol..i suppose they are better for hooking up once you do have the power though lol
Max
Mile High
Denver
I'd rather not spin my 20s let alone 24s. Tires are expensive as hell go buy some 16s if you like burnouts :cheers:
Rollin Thunder
Va Beach Va
I can spin in the yukon. Turn off TC pop it in R, floor it and spin city. Can get a mild chirp in drive, in the rain I get some spin. IN the silverado I get spin dry, and in wet weather get spin going from 30-50. If I start off wet in the silverado It spins even in second and I have to let off before it does a 180 on me.
Mr.Martin
NC
Even with everything in my sig my 2wd tahoe will still not turn the tires over unless its raining and im putting a little over 320hp down to the wheels.
---------- Post added at 01:25 AM ---------- Previous post was at 01:24 AM ----------
its a peppy truck but still not enough power to do a pppeeeeelllll out! :)
rossida
