Folding mirrors
bbogue4
I have a 2007 yukon and my side view mirror on driver side will not fold in.The pass side works fine but not the driver.When the button is pushed you can hear the motor trying to fold in but nothing.I would take it in to the dealer but our warranty just went out.If anyonre has had the same problem and can point out a solution that would be great.
Thank you
Nfamous60
Bronx, New York
when you hit the switch to fold the mirrors out try and push the driver side out it may be off tracc. my passenger use to do it but the when i close them one would start to fold then the other. I kept hitting the switch and it worked out i guess. sorry bout the warranty thing though. see they can do you a favor or sumtin.
05Yukon
Houston
Try folding it in manually and seeing if the motor will open it. It might be that it is just off track like nfamous said.
Scotto2323
NJ
Anyone have a problem with the whole mirror housing jiggling? My passenger mirror, where it fold has a little bit of play in it so that it moves pack and fourth as you speed up and then foward when you break. Anyone have this issue?
Harry Seaward
I'm pretty sure this was the subject of a service bulletin. I know lots of people were complaining about that with the '07. I've had lots of wierd stuff with my 07, but fortunately that wasn't one of them.
almenyawe
I Fixit
Hi,
I had the same problem with my (07 Yukon Denali) mirrors and managed to fix it.
I managed to disassemble the RH mirror,I found out that if you open the folding Motor , you can find 2 big Gears and a tiny worm Gear with Plastic regular gear head like the attached photo
By almenyawe at 2011-12-28
i found that warm gear heads are broken
I managed to fix it again with strong glue , reassemble:waytogo:
and voila it is working again
bryand178
Hi,
How did you get the power fold motor/actuator open?
1babygirl2000
I'm having the same issue with my passenger side mirror. It seems to close just fine...just much slower than the drivers side. I have tried opening it manually, but I do't want to keep doing this in case it's damaging something...ugh, I guess to the dealer I go.
bryand178
I bought a replacement passenger side mirror on Ebay ($50). It'll be here in about a week. Hopefully the power fold works as the seller claims.
GM Customer Service
Michigan
Please keep us posted of the results of your dealer visit.
Louis
GM Customer Service
mrknow88
The part bryand178 is holding and repaired is the main cause. A cheap little plastic gear. See this video that may help on how to at least get to the motor casing.
http://youtu.be/cIkaznUA9t0
hunterp27
For those of you that have this issue, please visit here: www.gmmirrorfix.com This is for any Tahoe Suburban Denali Yukon Escalade Sierra or Silverado.
dgwms
The reason our gm folding mirrors are not working is because GM saved a couple pennies by putting cheap plastic gears in the mirrors(plastic will get brittle and break with age). I just received 2 new HD motors and 2 brass gears (I will repair both mirrors) this will allow the mirrors to open/close faster than factory and less likely to break again (I only want to do this repair once). The kit was ordered from GruvenParts.com about $90, I'll re-post after installation.
mrknow88
Please post a direct link to the brass gear product.
BG1988
90$ is a rip off for two tiny parts
according to ebay prices the actual value is only $3 to $12... compared to other mirror worm gear prices . and motors are only 10$ i can get a worm gear motor 4500RPM for 15$
it will close your mirror in under 1/10th on a second!
Can someone get the dimension/specs on these? so we can order them directly from china
kbuskill
NE. FL.
I will stick with the brass gears and the standard speed motors... no need to be in a hurry.
BG1988
they have slow ones I'm just trying to get the sizing specs and just buy my own directly from china.... and fix my mirror.... without paying made out of GOLD priced parts..
yes the ones i see on ebay are made out of metal
for 90$ i can buy 2 grams of gold
kbuskill
NE. FL.
I wish you the best of luck... I replaced mine with the Gruven parts, and while I was reluctant to spend that much for what seems like so little... I have no complaints. They work great. I will never have to replace them again and they were much cheaper than buying replacement mirrors with inferior plastic gears. As a bonus to me, they are made in the USA by a US company so it helps support people here in our country.
If you do have success, post your results on here... I'm sure others would be interested in a cheaper alternative.
D Rollins
