purple 'hoe
Green Bay, Wisconsin
Replaced a front cv shaft, front shocks and seat track yesterday. And then smashed my back glass against the garage door trying to pull out with it open...
New glass will be installed Tuesday. $350 later..
LI99HOE
Top Notch Tech.
N.Y.
Had the upper and lower ball-joints on both side replaced, and a full (including front camber) alignment. $500 for the total job.
TTZ06
Houston, TX
Added more lights under the bumper. Hids going in these as well and relayed to my low beams with a switch
ch4d
A Podunk town in Oregon
how the hell was your timing off by that much??
no clue one bit just pops up one day and i am like wdf -.- so i take it in and i am like holy shit really? because i know people who work at the shop. They are like check this out -16 degrees i am like wdf??? then we reset to -2 and i went on my day. Happy with a bit more power to.
LI99HOE
Top Notch Tech.
N.Y.
Could a worn distributor gear be throwin' it off occasionally? How old is the one on there?
AtomicHoe094
Atomichoe094
cleveland, OH
was the nut/bolt tighten down all the way?? thats crazy but at least you didnt run to lean or something and really mess stuff up
ch4d
not sure honestly.
---------- Post added at 11:24 PM ---------- Previous post was at 11:23 PM ----------
yes and it was tight when we first did it then it came up again and then the second time we did it again and bolted it down.
retorq
Kingman AZ
Started it up and logged a quick drive around the block to make sure the notebook was working ... Gonna head to Speed World in PHX this Friday and want to log my first quarter mile run in the truck. :D
ch4d
well dropped mine off yesterday so i have no hoe for a few days getting some body work done to it... had a guy run me off the trail in the dunes. But i am rolling around in a 2007 duramax
qukon 95
while pulling my trailer i heard some squeaking from the
rear driver side when going over bumps thinking it was the trailer
well i unhooked the trailer and did some more driving
the squeak is still there. well it was the leaf spring
so i sprayed some lubricant on it and that did the trick.
ch4d
after work today i went ahead and got most of the swapping of the doors done the rear quarter panel got primed today and tomorrow we got to fix the front fender mask and prep for paint paint her and then put everything back together tomorrow with door handles insides of door etc.
bowtiefreak
No Quarter
Near Philly
Going to put a starter and new rear shoes on the suburban this weekend.
Also started and drove the red truck the other day, I miss it.
Kcrowe79
