DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
Installed the dash heater control panel I got from the wrecking yard. Doesnt work right. The heat finally comes on. However it only works on foot area. No other options on the gauge are working.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Did the electrical portion of flexalite efans. They don't make much noise. Did not have to adjust the thermo setting either. Acording to the scan guage the computer see a 193-198 temp reading with an ocassional 204 after shutdown for a bit. if running when engine is shut of the fans continue for a few moments before shutting off.
Now I still have to do physical fuel tank usage testing again but on the scangauge II average has gone from 14.7 to 17.6 on average mph setting doing the same 40 mile route. So when I get back on the road I will run the physical numbers to see what results come up.
I have a 17" x 34" 2 row radiator core.
MoroneSaxatilis
Tomorrow it's oil change time, since now that it got cold my oil gauge pinned. Hoping the oil and filter change fixes it and it's not the sending unit. Better high than low, I guess.
LI99HOE
Top Notch Tech.
N.Y.
I always liked the idea of the fan running a little bit after ya' shut down. Glad it worked out well..... this'll be goin' on my list of future "upgrades".
the big blue bus
richmond, va
put truck bars in mine. need to adjust em tomorrow rides like tank cranked too much haha but lifted the inch or so i needed. melted cv boot lil bit in process so need to clean greese and cover it till i can get new boot. taking it to get aligned this weeknd i hope
ISRT-HOE
Took out the heater core to test it as it was bypassed when I picked it up a few weeks back... seems fine but might still replace it for a new one since it's out. Also took out all of my speakers, 2- 4x10's in the roof and 2- 6.5 and tweeters in the front (1999 2 door LT) Replaced the fronts with Infinity Reference and waiting for the 6x9 rears to arrive to modify the mounts to fit them in. Still have stock radio and cd player and tested the cd player out for the first time and it has an err message... need to look that up and want to just try to fix it tomorrow while I decide on a deck, might go with the double din and remold the dash.
Oh Black friday, also ordered up more stuff... Got AVS 8 channel bolt on door poppers ordered! 33% off for Black Friday! Awesome, I planed on getting them anyway and it just happened to work out!
UPS came by and I received my intake manifold gasket sets from Amazon also... all today (or yesterday since it's 2am)
SunlitComet
OBS Jedi-Do Good
This only seems to happen when fan was actually on when when the ignition trigger is removed when shutting off engine. At $550 it is still pricey. And be prepared with hefty wire ties to tie the engine oil cooler line out of the way of the left fan. and some wire harness clamps to remount battery cable and fan wiring that goes across front end.
DefendHawaii
Snake Eater
Fixed the heater panel!!! It all works 100% defrost and AC both work as well! So relieved about this issue! Going to drive now over to oreillys or autozone and get a new muffler tip
IRQVET
2 Door Owners Club
Tallahassee, FL.
I changed my oil today, four quarts of Mobile 1 (10w30 Full Synthetic) and one quart of Lucus Oil additives. Current mileage at 101K.
MoroneSaxatilis
Changed oil today, had to use channel locks to pry off the old filter, oil pressure is still high and ticks between 60 and 80, so I guess sending unit might be next. Also noticed sludgy goodness in the coolant reservoir, so I guess a flush is in order....
AtomicHoe094
Atomichoe094
cleveland, OH
i like the old screw driver method of getting off old filters.. haha
Take a nice flat head, hammer it right threw the filter and spin her off. works every time, just a little messy
DefendHawaii
Snake Eater
Exactly how I had to do my first change on the Tahoe. Bought the fancy fram filter remover but
The old filter was some skinny POS from jiffy lube or something.
IRQVET
2 Door Owners Club
Tallahassee, FL.
Everytime I remove my oil filter its a fight to the death. . . . and here I thought I was the only one, lol.
MoroneSaxatilis
Worst part was, I had the sidesteps squeezing my chest, and my son, trying to be helpful, climbed up to shine a flashlight down through the engine bay, thus further crushing me under the side step. I thought my wife's Honda's filter was in a bad spot, the Yukon is a close second.
Merch619
